Results 1 to 5 of 5
Thread: Shell rimula rx3 15w-40 diesel engine oil ??
    alirmemon's Avatar
    Nov 2011
    44
    Default Shell rimula rx3 15w-40 diesel engine oil ??
    Any one using shell rimula rx3 15w-40 diesel engine oil in their suv's?? Is it good?? Any feedback??
    I have just used it in my 1kz diesel engine. Just curious. Thanks.
    sarmadqureshi's Avatar
    Dec 2007
    39
    1,594
    What oil was being used before ?I wouldn't want to change the oil type frequently as it can lead to what is called a detergent affect. Stick to good one oil & one good oil source!I used the shell in my 2.OD with very poor results. I swicthed to Caltex Delo Gold and it smoked less. I personally prefer the Caltex Delo, use that in my 3L & 1KZ-TE engines.
    TLC FJ90 SWB ~ 1KZ-TE ~ 50mm OEM Lift
    alirmemon's Avatar
    Nov 2011
    44
    Last used oil was Delo Gold. I guess I should have used the same. They didnt have it when I went there. I guess you should buy oil and then go to get it changed. I hope i wont have to regret it.
    baigaqeel's Avatar
    Apr 2008
    50
    2,693
    66 Post(s)
    9 Thread(s)
    yes
    buy oil, filter 1st & then go for change.
    I am using Delo Gold with no issue
    ishtiaqahmed's Avatar
    May 2007
    38
    41
    3 Post(s)
    Delo Gold is my choice for my CJ-5, 2C turbo, never let me down anywhere... And never thought of changing the brand...
    And then there was no road ahead. But there was a path to ride on.
