This instructable will walk you through the simple process of "burping" or getting all of the trapped air out of your cars cooling system. This works for ALL Vehicles
If you have had any parts replaced on your cars cooling system (radiator, waterpump, new hoses, ect) then there is a chance that your cooling system has air trapped in it and this could make your cars cooling system operate poorly, or in worst cases minic the symptoms of a cracked head.
So BEFORE you spend thousands of dollars at the mechanics having this done, try this and see if your cooling system operates normal (temp stays within normal , does not get hot or overheat).
[h=2]Step 1: Things you will need[/h]
AnitFreeze or Dex cool, I used the 50/50 water dexcool mix
Spill free funnel ($20.00 on Amazon.com)
Rag to wipe area clean
Time and Patience
[h=2]Step 2:[/h]
Make sure that your overflow tank is at the level of coolant where the line marked "COLD" is, make sure that you car is cold, do not try this with a engine that has been running.
Open your radiator cap, insert the angled peice of the spill free funnel into the correct cap for you car, then the main peice of the funnel on that, Make sure that you have all conections on sung so that there are no leaks.
[h=2]Step 3:[/h]
Now fill the funnel a little past half way, the reason for this is when your cars thermostat opens up the level will rise and drop with the opening and closing of it and with the escaping of the trapped air.
YOUR CAR SHOULD BE OFF, DO NOT START YOU CAR YET!!
[h=2]Step 4:[/h]
Go to your car, and set the climate controll settings to the hot or heat setting but make sure that the fan/heater is in the OFF posistion.
NOW you can start you car.
