Go Back   PakWheels Forums > Professional Forums > Articles / Driver Education / Safety
Old 19-08-2009, 12:16 PM
Carsrus
1,409 days old at PW
Default [Update v0.2] Guides to Tuning (- the Rice)
This thread is for anyone seeking advice on RICE, may he be young, old, or unborn...
Made with the styleless in mind! Don't worry, help is here!!
CAUTION: THIS THREAD CONTAINS NO "TYPE R" STICKERS
What is "Rice"?
Despite the name, this has no relevance to the edible grain. Many examples of "rice" can be found all over this, and many other car forums. Its basically people trying to be racers. Attributes include, but are not limited to:
1.) Loud, oversized, "**** Can" exaust.
2.) Oversized spoilers/Racing spoilers on FWD cars which don't effect downforce in any known way
3.) A body kit that has gives no gain in aerodynamics, usually causing extra drag/turbulence(under the vehicle)
4.) Windows tinted in such a way that nothing is visible at night
5.) Names/Email Adresses/Phone numbers stickered to windows/other panels
6.) Stickers of autopart/racing companies that either don't exist or have no role in the car's preformance. The most typical example is the TYPE R sticker tha only applies to TYPE R Honda's.
7.) Off center vinyl/sticker stripes.
8.) Excessive Chrome
9.) Large rims
Ride owners are usually refered to as "Ricers" or "Wanna-be's"
Then you may ask:
How do I prevent my ride from becoming "Rice"?
There are a few steps to follow to ensure your saftey from being "Riced". First and foremost, do not do anything mentioned above. I also recommend the following:
1.) The easiest and BY FAR the cheapest thing you could do to your ride is wieght reduction. (Not recommended for long distance/daily used cars)
Gains: +Handling +Style (Rims) +Acceleration -Weight -Comfort
Step 1
: Remove rear seats,
spare tire and jack, radio/stereo.
Step 2: Purchase light wieght rims. A perfect balance of rubber and rim are extremely important, too much tire and they wont heat as fast, too less and they'll heat to quick causing a less comforting ride and extra wear. For most vehicles, the best sizes are between 16" and 17". (SEE SECTION 8 FOR RIM ADVICE)
Extra options:
Adv. Step .5: Remove Dashboard and interior door panels
Adv. Step 1: Replace front seats with light weight racing seats.
Adv. Step 2: Replace hood/bonnet, doors, and boot/trunk lids with carbon fiber
Adv. Step 3:
Replace rear glass with light wieght plastic inserts.
Adv. Step 4: Replace tires with wider, grippy-er treads. DO NOT USE SPACERS, THEY WILL FLY OFF!! (I say this from experience)
2.) Suspension. The suspension is the prime link between the car and the wheels, and you definitley don't want your car bouncing around at high speeds with the current state of our roads.
Gains: +Handling -Weight +Comfort +Style
Step 1:
Replace/add sway bars. By adding sway bars, you reduce body roll of your vehicle
thus keeping your wheels firmly planted through fast corners.
Step 2: Change your springs from stock to either sport shock/spring kit or "Progressive Rate lowering springs" which lower your center of gravity in turn adding style and handling without compromising the ride quality.
3.) Brakes, Corolla owners ignore this step. If you can't stop, there is no need for power. YOU NEED BRAKES BEFORE YOU UPGRADE YOUR ENGINE, ITS TRUE! Brake later and accelerate sooner. Its a racing proven formula.
Gains: +Handling +Weight/-Weight
Step 1
: If you still have stone-age drum brakes, I highly recommend upgrading to disks. If you do have disks, make sure your system is up-to-par with the speeds you will be going.
4.) Transmission. Puts the engine's power to good use. This step is primarily to ensure all of your horses will be put to use.
Gains: +Acceleration -Weight
Step 1
: Replace your clutch with a light weight performance option and replace flywheel with something more light weight.
Step 2: Poly Transmission and Engine mounts
reduce drivetrain flex exaggerated by rubber mounts. They also eliminate "chattering", missed shifts, and broken parts caused by drivetrain flex.
Step 3: Replace clutch cable with more responsive pedal feel.
Step 4: Short shifters feel alot better and give you a better feel. Mazda pulled this off beautifully with the MX-5 Miata. You can remove your knob and cut about 1.5" off the stick which will give you a better feel.
Step 5
: Update transmission fluid to a more expensive brand. You WILL feel a difference.
5.) Engine Mods (FINALLY!). You can't just be all show, you're going to need some "go". At times, an engine swap is the only real hp booster. Start off with a general engine check up.
Gains: +Acceleration +Top Speed +Weight +Style
Step 1
: Improve stock intake by replacing filters with OEM replacements from K&E.
OR
Change your set-up to a Cold-air intake. I highly recommend K&N system with a K&N air bypass valve. This valve prevents hydro-lock if your system becomes submerged in water. This step will add up to 15hp
Step 2
: A better exaust will flow better and produce a better noise. The cheapest option is to buy a hi-flow exaust muffler and and wielding on pipes to fit your ride. Or, you could opt for a full cat-back system and thermal stainless steels are a good option. Cat-backs often give ~6hp gain, which is little for the amount you're paying.
Step 3
: Update headers to polished/port matched/knife edged
Step 4
: Plugs can be switched at anytime so this step can go anywhere
Thats about 20+ hp
Adv. Step 1
: Turbo/Supercharge with EXTREME caution. This step may add as little as 20 to 100+hp. AN ENGINE SWAP MAY BE MORE SUTIBLE!!
6.) Downforce. This applies to cars that will be traveling in excess of 60mph or 96/97kmh. For FWD cars i recommend a front lip spoiler. They reduce airflow under the vehicle and re-route it to the intercooler and radiator. Front lips push the drive wheels into the ground for more grip and handling. For RWD cars, small spoilers do the trick without giving you a ricer status, as seen on BBC's Top Gear with the Konieggsegg. Spoilers do add weight, sobe cautioned when adding a very large one. FWD cars should only resort to rear spoilers if tey are traveling in excess of 80mph/120kmh or the back "slides" or "kicks out" during high speed turns.
Gains: +Handling +Style +Weight -Acceleration (due to drag)
Before buying new parts from suppliers, save a buck and check the market. For example, a 95 Civic can use brakes and updated parts from newer models. Look around the market before ordering online!
7.) Now we can move on to stylin' your ride with the following in mind: Simplicity is key. Start of by getting your stance right. Most cars go for the low stance where all all wheels are an equal distance to the body. Another stance is a Muscle type stance where the front sits .5-1" lower than the rear. To accompany this stance, rear tires and rims are slightly larger and wider.
By getting the stance first, you will be able to dertermine the question that seperates the Ricers from Men (Ricers don't have... well, you know.....STYLE): DOES MY CAR REALLY NEED A BODY KIT? If the answer is yes, follow the steps below:
Gains: +Weight +Style
If you are a true "Anti-Ricer / Tuner" then you'd go for the lightest kit available. Remeber, you don't need to go for a kit with a front bumper/side skirts/rear bumper. You can buy parts individually.
Step 1
: If you feel your car needs a little dash of something, start of with a front lip if you haven't so already. Most of the cars in PK are JDM or PKDM based off of JDM vehicles. You can either buy one that fits onto an aftermarket front bumper or one that fits onto your stock bumper.
Optional Step 1
: If your car still needs a little zest, buy an aftermarket front bumper. Since your car is already low, I've prevented you from buying big rediculous bumpers, so HA! You're stuck buying something small! HAHAHA!
This isn't a bad thing though. Observe the following vehicles:
They have one thing in common, they are tuned and have aftermarket bumpers that are small and dont scrape the ground. AND, most importantly, THEY LOOK GREAT. If you look at the second picture, most front bumpers come with either fog lamps or places to insert them. From here in te US, you can get fog lams for as little as $6, or Rs.500. They add a stunning quality to the bumper.
Step 2
: Side skirts can take your "lowered" stance to a new level. As seen in reference picture 2, a simple straight skirt can go a long and low way.
Step 3
: If that still isn't enough, go rear bumper hunting. Before, or along with, your rear bumper you may want to buy some flashy exaust tips. THAT DOES NOT MEAN THEY SHOULD BY 12INCHES IN DIAMETER AND YOU SHOULD BE ABLE TO LOOK INTO THEM! Take a look at this:
http://www.summitracing.com/parts/HED-17165/
They have to be the most attractive tips anyone has ever concieved. And guess what ricer scum, they're only 2.5" in diameter. A WHOLE LOT smaller than the typical 6" tips on every tuner in Pakistan.
Back to the bumpers, you want something that flows with the rest of the kit but at the same time complementing your tips. Well guess what, lip lovers there are also rear lips to match the front:
Instead of a real show-shine bumper, lips pull of the task of style efforlessly. Best of all, lips are light weight compared to full bumpers.
Optional Step 3
: If you are opting for a full rear bumper consider the following: Go simple. Most body kits in Pakistan have many curves and are to complicated to please a human. I would compare the shape to Chuck Norris' leg. Believe me, that shape isn't appealing. Go for something that looks as close as stock to possible, but at the same time adds a few vents, lines, and a place that your tips will look good. Here's and example:
2nd Optional Step 3
: You can also opt for rear bumper "aprons". They're like fender flares, except for your bumper. They're little attachments that go into each corner like this:
Once they're installed, they look like this:
Whatever styling conclusion you've come to, and as long as you use this guide, I'm sure it'll be great.
8.) Next, you can choose a paint job and, if you haven't so already, rims. When buying rims, always remember: CHEAP CHROME IS FO' BALLAS'.
Becareful when choosing between more vs. less spokes. Complicated car designs are complimented by an increased amount of spokes while less complicated cars are complimented by a decreased amount of spokes
Chrome doesn't belong on Civics or Corollas! Here are some tips on how to choose your rims (sorted by rim color):
Gains: +Style -Weight +Chicks
Our first color is gunmetal. This can go with, really any color, but looks exceptionally well with:
Gloss(non-metalic): Red, Blue, Yellow, Black, White, Orange
Metallic: Black
[img]file:///C:/DOCUME%7E1/Youshee/LOCALS%7E1/Temp/moz-screenshot-4.png[/img][img]file:///C:/DOCUME%7E1/Youshee/LOCALS%7E1/Temp/moz-screenshot-5.png[/img][img]file:///C:/DOCUME%7E1/Youshee/LOCALS%7E1/Temp/moz-screenshot-6.png[/img]
[img]file:///C:/DOCUME%7E1/Youshee/LOCALS%7E1/Temp/moz-screenshot-7.png[/img]
[img]file:///C:/DOCUME%7E1/Youshee/LOCALS%7E1/Temp/moz-screenshot-8.png[/img] Our second color is white. This is my absolute favorite type of rim, specifically because it signifies a light wieght rim. When Purchasing white rims, make sure they are not painted. They typically go well with:
Gloss: Yellow, Blue, Red, Orange (but not white)
Our next color is Silver or Brushed Metal. These go well with any car.
Our final rim color is bronze. Bronze rims are an EXCELLENT way to complete the look of a tuner. They look simply stunning with various gloss colors.
9.) Decals. (coming soon)
Topic Updated
__________________
The kid who didnt play racing games at the arcade because it didnt have a clutch.
Carsrus is offline   Reply With Quote
Old 31-08-2009, 11:04 PM   #81 (permalink)
885 days old at PW
i've read.
very nice.
__________________
Margalla Rocks!!!!!!
My car is my Girlfriend.
My Ex Girlfriend died. :-(
jazzy77 is offline   Reply With Quote
Old 04-09-2009, 08:42 AM   #82 (permalink)
116 days old at PW
Quote:
Originally Posted by shree59
aqeelmand admi ha
__________________
I ªm wUt ¡'m.... U c0uld |¡kE it 0r |ovE ¡t ....| DUn nEEd ªnY permiSsiOn ...i mªDe mY oWn DeciSi0n's!
Sheharyar_92 is offline   Reply With Quote
Old 04-09-2009, 09:32 AM   #83 (permalink)
1,021 days old at PW
Quote:
Originally Posted by 4DoorHoe
forza 3 is goin to beat gt5 check forzamotorsports.net its coming out in october they have mad cars in there i hope u got the money and stuff yuzi nice playin with u but u left after ??
Nah, I still play GT4 even though I got Forza 2. Theres just too many cars for forza to match. GT4 had 700+ cars and Forza 2 has only about 500. The new forza is going to have 700, and the new GT5, 1000+ cars. And they have Rallying
Has anyone honestly read through the topic [updated]?
[/quote]
Nice upDate Bro
__________________
!!!MOD/ CutsomizE Not RIce-=-=-=-=-=-=-
A Ricer is******* a stupid idiot who thinks he is a car expert after watching The Fast and the Furious, Pimp My Ride, and playing Need For Speed Underground. It is also used to describe the completely overrated(PAINDOO) car.... With Vinals And Stickers AND litghts EVEry WHEre,,........THat doOO NOt Look GUD.. I RePeat Do NOt Look GUD...
!! ALso Wid A UN MaChing BOdy KIT and Un Matching Of Car LOgOS
furious_nd_fast is offline   Reply With Quote
Old 04-09-2009, 09:39 AM   #84 (permalink)
685 days old at PW
Zabardest (y)
__________________
R.I.P
internal_auditor is offline   Reply With Quote
Old 19-09-2009, 12:12 PM   #85 (permalink)
jz
1,809 days old at PW
lol nice replies toofast
now thats some real ricers
__________________
performance plugs for sale @ ]]]
http://www.pakwheels.com/forumreply_az_TopicID!102873~ForumID!12~page!2~msg!ucmt~pw.html
5inch tip performance exaust for sale,contact @ 0323-4222772
jz is offline   Reply With Quote
Old 22-09-2009, 08:26 PM   #86 (permalink)
Third request to mods- Change topic details to:
mod edit: advertising other sites is not allowed @ pw.
Change topic name to: [Update v0.2] Guides to Tuning
__________________
Old 23-09-2009, 08:49 AM   #87 (permalink)
CHANGE THE TOPIC CONTENTS TO: Guide published to
4TH REQUEST TO DO SO. Otherwise, thanks for changing the topic title.
mod edit: ur welcome
__________________
Old 23-09-2009, 11:18 PM   #88 (permalink)
1,572 days old at PW
please note that we can't to update ur topic as advertising other pk sites is not allowed.
thnx
__________________
we'll miss u...
ahsen_rg is offline   Reply With Quote
Old 05-10-2009, 06:31 AM   #89 (permalink)
^ IS @libra planning to give me some hosting space ?
Guides to come:
Off-Road Tuning
VIP/Jp Tuning
Muscle/Hot Rod Tuning
__________________
Old 05-10-2009, 06:36 AM   #90 (permalink)
444 days old at PW
Are you really 17? And well quite honestly you have way too much spare time on your hands, this needs a great deal of research or something like that
Keep it up man (Y) i appreciate the intentions
__________________
It amazes me that every time you open your mouth, you prove yourself more of an idiot.
RetardedBuddy is offline   Reply With Quote
Old 15-10-2009, 04:14 AM   #91 (permalink)
^^ Took me 3 days and 2 updates.
Heres a funny pic I couldn't resist posting:
__________________
Old 04-11-2009, 10:06 PM   #92 (permalink)
207 days old at PW
hahah
this is the funniest THREAD ever!!
LOLX
may be
LMAO
__________________
M ASFANDYAR SHAHEEN
shaheen69 is offline   Reply With Quote
Old 05-11-2009, 08:28 AM   #93 (permalink)
Thanks for the compliments (Y) I've added a hood section on my website (which I dont have permission to post) so prepare for an update.
__________________
Old 17-11-2009, 11:46 AM   #94 (permalink)
685 days old at PW
Please explain this statement mujhe samajh nahin aye
__________________
R.I.P
Old 17-11-2009, 03:17 PM   #95 (permalink)
444 days old at PW
He's saying that one must upgrade his brakes before the engine because it doesn't matter how fast you can go until you know how quickly you can stop. Me being a corolla owner totally agree with that... The part of the corolla owners ignoring this step was sarcastic.... All clear my friend?
__________________
Old 17-11-2009, 03:48 PM   #96 (permalink)
685 days old at PW
@RB --- Thanks
__________________
R.I.P
Reply
Bookmarks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are Off
