What is the current condition of N5 .. I shall be leaving on 30th May In Sha Allah,,
Need the info on N5 from karachi to Bawalpur ... and the best time to leave KArachi?
good family hotel to stay the night in bhawalpur..???
I am also leaving on same date with my family, inshaallah! as not sure about the latest N5 conditions, my first stopover would be at RahimYar Khan. Last year Karachi- Rahim Yar Khan took 12 hours due to bad N5 conditions and on return from Mehran highway took 10 hours but Mehran highway is single throughout. Moreover,I recently talked to one of the transporter, according to him till Rani pur work is completed but few diversions are still there in between Rani pur and Khair pur section.Regards,Zia
Which road is called Mehran Highway?
Regards,Zia
Staying on n5 wud be a better option,., .as I will also try to stick to n5.. its double road thru out..,, to avoid traffic jam.. leave karachi early.. say around 3 in the morn, ,
The Mehran Highway is a better option. The road is safe also. The turn comes after immediately Sakrand Bypass, you can read the sign "NawabShah" to right in order to access the road..
If you are proceeding with family, I will recommend traveling on N5 only.
N5 is much much better now, Ranipur and around is under construction, better to take Nehar waali Pulliiaa at Gambat and bypass Ranipur.
any diversion sign for Nehar Wali Pulia??? . Gambat comes after rani pur whn going up country..
Almost 40% light traffic use that puliia, many cars will going there its before ranipur toll plaza.
Security situation around this pullia????
Its fine, even I travelled from there around 3:30 AM.
Usmani Sb,.. what wud be the best time to leave khi ??? if taking n5....
Dear Farhannk
As I traveled on the same route last year, you should commence your journey from Karachi at 0500 hours. At 0700 hours you will be at Hyderabad and till 1000 hours at Moro. You can take some rest here. After that at about 1300-1330 hours you should be at Rohri - take lunch here. Continue journey and you will be out of Sindh at 1700 hours with an average speed. You can reach Bahawalpur at 2100 hours easily . Best of luck.
Thank you Usmani sb, In-sha allah tomorow morning after Fajar namaz will start the journey. Need prayers ..
Kindly update on road condition as i plan to leave on 11th at around 4:30 am.
