If possible, change the oil in both Front Forks. It will give you a smoother ride with better handling.
Just take the caps off the Front forks and drain the oil.
Replace with new oil.
Check your Clymer service manual for the correct amount of oil to fill in each Front Fork leg.
Good luck!
