Honda CB Trigger CBS Technical Specifications
Engine
Engine Displacement (CC)
149.1 CC
Engine Type
Air Cooled, 4 Stroke, SI Engine
No Of Cylinders
Power (PS@rpm)
14.1 PS
Torque (Nm@rpm)
12.5 Nm
Fuel Type
Petrol
Drive Type
Chain
Transmission
Type
Manual
No Of Gears
5
Gear shift Pattern
1-Down 4-Up
Brakes
Brakes Front
Disc
Brakes Rear
Disc
Performance
Power to Weight Ratio
Data Not Available
060 kph (sec)
Data Not Available
0100 kph (sec)
Data Not Available
0400metres (sec)
Data Not Available
Top Speed (KPH)
117
Braking 600km/h
Data Not Available
Overall (KMPL)
60 (Claimed)
Suspension
Suspension Front
Telescopic
Suspension Rear
Monosupension
Tyres and Wheels
Tyre Size (Front)
80/100 - 17 M/C 46 P
Tyre Size (Rear)
110/80 - 17 M/C 57 P
Wheels Type (Pressed Steel/ Alloy)
Alloy
Tyre Make
Data Not Available
Wheel Size
17
Dimensions
Minimum Turning Radius
Data Not Available
Kerb Weight
137 Kg
Length*Width*Height
2045*757*1060
Wheelbase(mm)
1325 mm
Ground Clearance (mm)
175 mm
Fuel Capacity (Litres)
12 Litres
Fuel Economy
Overall
0 kmpl
