mene 500RS ki li thee shyid brand new is around 1.8K and beam is good if high power bulb or H4 tube is used.
Moazam ... as per my poor knowledge ... redline of any engine starts after its rated/Max performance, CGs and paiggio redlines after 8.5k RPM but in RP on meter the early red numbers are for rider alert if u notice the speedo meter is also in red just after 80 to let rider kow you are on relatively high speed for a bike that small.
yep, same is in speedo meter as its red after 80kmh
GS150 has a much early peak power number its produces max at 8k RPM and as you might have heard ansee that to make it launch correctly you have to be with in the power band not more or you may find it making bad top speed which happens most of the time...
