don't go for older model clutch box it wouldn't be easy to find and any mechanic who would have it would sale it at skyhigh price and what would you do If it didn't long last I would suggest you to put a sazga ricksha's clutch box bolt to bolt on cg and it will also boost you bike's performance
dont ever think about it putting sazgar rikshaw clutch boxa would do nothing but alter it, it's mainly used by wheelers to set in 6 clutch plates for better pick and crazy acceleration in result weight gives up before the its time period or engine life... older model clutch box isn't sky high price easily available everywhere and cost is normal... try to stick with genuine else contact me I will tell u the secret to void that noise done in dozens of cg's here at khi including mine lol
don't tell me the secret is to sell the crappy bike I remember that you sold your cg
Deluxe ka clutchbox dal lon?
Sent from my LT30p using PW Forums mobile app
delxue is no more an option with a price tag of 124k
he mean too say sell your cg and buy deluxe even deluxe clutchbox is bigger than cg classic
Cg euro 2 hai hi bekaar..paise hi zaya krwae apne father k
Kassh abhi b cg ki ye quality hoti.
mai ne tou kuch nahin kaha aesa... simply aik chez hai i will send it to u which im using, removed the noise and sorry to say who said its bigger ?
Kya cheez?
cg deluxe clutch box is big becoz delxue have longer stock and higher cc than classic which is 124 cc and deluxe is higher cc than classic the crank weight used in cg classic are for 107-124cc piston any thing bigger will need bigger crank weight which is the same case as with deluxe AHL gave a bigger clutch box with cg deluxe to increase the torque https://www.pakwheels.com/forums/bikes-3-wheelers/221167-engine-level-difference-b-w-cg125-powerplus-s-5g-sprit-deluxe-pictures-attached-2
here i will just give you smile
Higher CC? Are you kidding me?
CG125 CLASSIC:
CG125 EURO II:
SG Spirit Deluxe 4gear, 5gear, non Euro and EuroII all of them:
deluxe have longer stock
Quality is same
Jaane do bhai..sb local parts hain..ab Japanese name ki hi hain..japani hai kuch nai.
The model which you have mentioned in your earlier post is also not japanese.
Sent from my LT29i using PW Forums mobile app
I know brother likin us waqt local parts boht kam the. zayada parts Japan se ate the..
