@alpha13! I'd judge better if i see a picture of the accident to tell you better.
Not to worry Though. Find any Denter Workshop, specifically who deal with Bikes. He will disassemble the front of your bike, including the front suspension including stem steering (عینک), and he will try to straighten it out using hathoras. In most cases it will work just fine.
You will have to change some balls for stem steering, which help your bike's handle turn. At best you will have to spend Rs.500.
In most cases like this, Stem Steering (which hold your front portion with the bike, as well as the front forks) has to be changed. I learned this after some bitter experience. So IF, after this repairing:
- you feel that your front forks are not working properly (as in they are getting stuck between fork travel etc), or
- your front portion feels mis-aligned
... then get a brand new stem steering and change it.
