BTW, price sounds pretty reasonable provided they've good build quality and motor... And lets not forget E-Bikes doesn't need oil/air/fuel filters, engine oil, seals, gaskits, tuning, valve clearance etc etc. Just recharge and go... They rarely need any major maintenance. My only concern would be range...
My few questions:
How far this thing goes per charge?
How much time it takes to charge up the battery to 100%?
What kind of battery does these scoots use? Acid or dry?
What about maintenance schedule?
Can anyone shed some light? Thanks.
A 20 AH battery:
Discharging rate: 20 Amps per hour
Charging rate : 8 Amps per hour
if battery is charged for 6 hours: 48 Amps consumed (might be battery will not be fully charged in 6 hours after continue usage as the efficiency of charging rate decreases)
If the supply voltage is 230V, the power in watts is V * I. Thus a 2 amp load is 460W so,
Total electricity used for 6 hours: 11040 Amps
One unit of electricity is an average power of 1kW for 1 hour
Units used in one charge of 6 hours: 11
If one unit cost Rs 10 including all direct taxes, indirect taxes, bank & service charges
one day cost/one charge cost : Rs 110
If one day travel is 80KM so cost of 1 KM is Rs.1.375
Monthly cost : Rs 3300
Yearly cost: Rs 39600
after 15 months a new battery will be required which will be of Rs 15000
so next year cost would be: Rs 54600
So next year per KM cost would be: Rs 2/KM
if your current cost is at least above than Rs 4/KM then you should go for this ride
Note: raining/Dew can be disaster for winding in motor& battery packs(until unless the equipment is waterproof)
If your petrol bike gets broken while riding you can get to any mechanic , incase of Electronic bike you would have to drag it!
I have seen electronic bikes in market in year 2011-2012 these were being imported by somebody else with the same identical designs but speed/torque no doubt are improved in the bikes imported by TazTrading
Chines Rechargeable Mopeds launched in Islamabad
