#1 |
well guys there have been so much threads here on this topic, so a noble thought came to my mind tht i should make a STICKY thread which should discuss each and everything of SPRINTER and ECO...
so ALL STORIES GO HERE and plz dont bother to make any other thread.... thnx...
__________________
Da OnE aT iTz XtReMez.... |
#2 (permalink) |
i had a suzuki sprinter 2006 model...and it was just awesome...it was fast as hell and yet highly fuel efficient...
the best thing about it was the accelration ...i used to beat 125s with it...but it had some engine problems but they were gone automatically after sometime... i found two bad things with it...number1 ..BRAKES and number2 the hard seat....apart from that this is the best bike around in the market...buy one if you want speed
__________________
]]Time Doesnt Heal Wounds...A Kawasaki ZX-6R does <<
#3 (permalink) |
ahem ahem!! i have two of 'em at my house
..btw thnx for post the very first reply...yaar one MULTANI member just called me and he said hes comin on GT with his SUZUKI SD 110.. ru coming or not? as u are also from multan
__________________
#4 (permalink) |
@ xtre
yes some1 called me from MultaN most probably he is coming w his bike SD110 the full Japanese suzu Bike i belive it was the best the prob was: WE DIDNT CARE FOR THAT BIKE WHEN IT WAS SOLD N ASKED FOR THAT BIKE WHEN IT WAS DISSCONTINUED a tregedY
__________________
Pakisten Bikers Club: Game of Responsibility |
#5 (permalink) |
ECO:
1- japanese engine, more torque, no vibration, more economy on long routes, cylinder made of Aluminum Alloy 2 lower engine heat. 2- 12 volt brigfhter lights n signals, 3- bigger n relaxaing seat 4- new gear pattern, 4 speed contant mesh transmission system. 5- dia from carburator: gives regular n continuous engine running, n best fuel economy. 6- auto de compression system: auto low pressure system helps to start bike with easy movement of foot. 7- furl tank n side covers: strong, fuel tank w more ltrs, n beautiful stickers on tank n side covers. 8- strong shock absorbers: better shocks w dust covers, w better back shosks system bikes runs evenly on uneven roads also, for more or less weight 5 WAY PRE LOAD ADJUSTMENT OPTIONS: helps adjustment according to weight n makes your journey more entertaining. 9- swing arm: 1st time in pakistan, rectangular shape latest design SWING ARM is very strong n even. it helps 2 face more load so both riders enoy the journey.
__________________
#9 (permalink) |
My eco has covered 1000km. Chaged the oil 2nd time. Some times i feel broblem in gear shifting from 3rd to 4th. I press several times but it doesnt work.I still feel tha the bike is heavy to pull or accelerate. I usually drive at 60km/h some times touch 70 but not quite often. I am running it in reserve(fuel tank) mode cause in on mode bike starts missing. i fear some water or some other impurities in petrol.
#10 (permalink) |
@ seagoat!
have u got ur bike tuned for the first time?? did u mention this to them?? im quite sure the MISSING ISSUE is due to some prob in the PETROL...nothin else...and abt GEAR SHIFTING, thtz not a big prob either...consult the SUZUKI MECHANIC for it...i think theres some part of engine which needs to b greased or something... aur if u have got it tuned,....zyaada say zyaada bike ko KHAINCHAIN..rev it up at max...try to get teh maximum gear ratios u can...this will help alot to increase performance...
__________________
#11 (permalink) |
Well i also met another ECO owner he also complaint of bike running heavy not an easy goin like some other bikes..
and now u have completed ur running i was reading some where a guy a gora mechanic famous one he said the right way to running or break in is to every time u shift gears from 2 to 4 always rev ur bike high in 2nd and 3rd gear like on rpm normaly bike have 12 so go up to 9 or 10 do this and as u shift to 4th now come to smoth riding this wont effect your engine bcoz it wont heat up the engine and also the rings will set in properly only bad thing in running is when u over heat ur engine so this is a good way ![]() Baki gear prob will be solved as its under warranty the fuel prob look like some prob with fuel tank valve and also the stick we have inside the tank... Keep us Updated
__________________
Speed costs money, how fast can you afford to go. |
#13 (permalink) |
salam to all of you
yar plz tell me about the pickup of sprinter eco i hav diven it when it was just 20 km droven i feel its pick lower than junoon is it true or just my feeling? hav somebody felt that kind of thing?
__________________
i m one of those bad things which happen to good people. |
#14 (permalink) |
Well considering Junoon is just 100cc its still competes very well with Sprinter which is 110cc but i think the build quality of Junoon its engine is better then Sprinter bcoz i have talked to many owners i didnt find one person who have said anything against the bike but i have talked to many Sprinter owners 50% of them have some probs with the bike..
But Junoon wont give u 60+ kmpl for sure its around 50kmpl even some owners said below 50.. i met a yamaha mechanic he had a 100cc 4 stroke yamaha he said his bike gives 35 :p Many sprinter owners complain about bike being heavy and pickup not good when its new maybe it improves as engine breaks in nicely Extremist can give us more details bcoz he have 2 of these at home...
__________________
#15 (permalink) |
waiting for XTREMIST reply on the pickup of eco as compared to junoon............................................ .................................................. .................................................. .................................................. .................................................. .................................................. ..................................
__________________
#16 (permalink) |
mon2006us!!
yaar i dont know abt SPRINTER ECO,im also afraid tht its performance is slightly lesss... but i do know abt SPRINTER......and yes in the INITAL STAGES, when the bike is under RUNNING, its pick isnt tht much...ok let me tell wht i did to my bike after running... During running process, i wasnt getting the pick which i wanted...but i didnt get nervous coz my cousin alrdy owned it and he told me tht this bike keeps increasing performance by time....so after 1st tuning i started REVING IT UP....getting 40kmph from 1st gear, 70,80kmph from 2nd.... after 2nd tuning my bike performed really very well but still not competable to my COUSIn's sprinter...but after 3000 kms,it was perfectly set and its pick was more than my xpectations...if u were in lahore then i would have showed u what my bike actually is... ...and this has been the case with the 2nd sprinter..btw aaj kal jo bhi mujhay milta hai and asks abt SPRINTER ECO , i always say him YAAR 50000 Spend ker saktay ho to y not go for a reliable thing (SPRNTER) for 4k more?? i'd also recommend u to go for SPRINTER..
__________________
#17 (permalink) |
salam to all of you
@xtremist and all other guys participating in this forum. as you know now a days i m in progrees for a exchange of cd 70 wid an eco. my neighbour bought it yesterday in red color. i was so impressed of it that today i made a perfect plan to buy it. but as i was just out of my home wid my father to sell cd and to buy an eco he met me and told me the thing due to which i change my decision. he told me a very shocking news its avrerage it is just about 40 KM\LITER ON LONG ROUTE absolutey confused i m now. bro plz tell me that what is the average of your neighbouring ecos? i m very shocked to hear that. plz post your comments
__________________
#20 (permalink) |
check the 3rd last reply by SEAGOAT in this page...and we dont know at wut speed ur friend was driving on LONG ROUTE,....laikin agar bohat speed pe bhi chalaao it doesnt make so much difference,,,he must b mistaken
http://www.pakwheels.com/forumreply_az_TopicID!15083~ForumID!22~page!23~pw. html
__________________
| Bookmarks |
| Thread Tools | Search this Thread |
