Keep your car cleaner, longer.
Give your car the new hard-shell finish that lasts with Turtle Wax? ICE?. Not only do ICE products give you the shine you'd expect - their advanced formulas make it easy to keep your car cleaner, longer.
ICE is a new product from Turtle Wax that is also a non-wax promised to result in no white dust, can be used on just about all surfaces of your car short of tires (though they make a point of saying it can be applied to rubber) and windows.
ICE is also touted to provide deeper shine through multiple coats (for this comparison, I only applied one coat).
Repels dirt for shine and protection that lasts.
Turtle Wax? ICE? Liquid Wax delivers a long-lasting shine that repels dirt. Shine resins and protective polymers lock on to your car's exterior to keep it cleaner, longer.
Can be used on all car exterior surfaces, even flat paint, plastic, glass and chrome
Faster and easier to apply than conventional waxes
Makes it easy to restore your car's shine with a quick rinse
Won't leave a white residue and can be applied in direct sunlight
Breaks down dirt to reveal your car's shine.
The breakthrough blend of advanced cleaners and conditioners in Turtle Wax? ICE? Car Wash gives your car a breathtaking clean. Formulated to easily break down and remove dirt and soils, ICE Car Wash is safe for even the most delicate car finishes.
Washes dirt completely away to prevent re-depositing, swirls and scratches
Is pH-balanced to remove environmental contaminants on paint
Helps your car keep a "just waxed" look
Is biodegradable
Same brilliance, less work.
The long-lasting shine and protection of Turtle Wax? ICE? is available in a spray. Turtle Wax ICE Spray Wax works on all of your car's surfaces and can restore you to a showroom shine in minutes. Easy to apply, ICE Spray Wax goes on in direct sunlight or shade and requires little buffing.
Takes out the guess work by putting the right amount right where you want it
Protects clear coat paint and factory-coated wheels
Add a quick, slick, unbeatable shine.
From quick touch-ups to giving your car a mirror-like gloss, Turtle Wax? ICE? Detailer is an easy way to keep your showroom shine. Formulated to work with Turtle Wax ICE Liquid Wax, ICE Detailer boosts your car's shine while still protecting it from the harshness of the road.
Goes on quickly and is simple to use - no drying time, only one towel needed
Fills in swirl marks, removes light dirt and water marks
Can be applied in many coats, without heavy buildup or streaking
Clean, shine and protect - inside your car.
Turtle Wax? ICE? Total Interior Care is an all-in-one cleaner that makes your car interior shine. Formulated to work on soft vinyl, plastic, leather and other surfaces, it removes spills and grime and leaves a protective barrier to keep your interior cleaner, longer. Best of all, it won't leave an artificial sheen or a greasy, slippery feel.
Restores a like-new sheen to plastic and leather
Deep cleans to get rid of unwanted odor sources
Sprays where you want it, with a nozzle engineered to get into the tightest areas
For more details please join
www.facebook.com/TurtleWaxPakistan
