AOA, i need some help here. There is a elfi drop on my cars fender which runs all the way down. I have tried to compound it but doesn't go away . Any suggestions?
I am facing the same issue, but My Elfi Drops are on Front Glass
Any Suggestions?
rub few ice cubes on the affected area and it will skin away tajarba shart hai !
you will have to clay it off (it will take time, elfy is stubborn)
once most of it is gone you will be left with a slight stain on your paint where the elfy used to be, you will have to compound the stain
this method has been previously tested
Its worth a try... I keep elfy in fridge... it doesn't get dry and can be used many times. May be ice can melt it somehow.
Sent from my HTC Desire HD using Tapatalk 2
hey thanks bro for the Tip....from now im gonna keep my elfy in fridge
Btw there is a chemical "ACETONE" it is used to remove super glue...but im not sure its safe for car paint or not...
It will eat your paint. don't bring any thinners close
clay will take too much time to remove, these dropswet sanding on effected area with hot water till the clear coat appear and then use compoundvery fast and effective way to get rid of these drops
Same prob with me on trunk ? Willl icecube work ?
Sent from my HTC Explorer A310e using Tapatalk 2
Use a hair dryer or make that area hot elfi utar jaye giI tested it on my camera jis par pori elfi gir gaye thi
Keep washing it with water. It will break away.
Sent from my GT-I9103 using Tapatalk 2
only sand paper and repaint worked on my charades trunk but it was a old car repainted car
i hope people mentioning elfy damages above dont have new cars
i tried the nail polish remover ---> didn't work. Secondly i tired hair dryer and then soap water ---> didn't work . Whats next?
scratch it off. end of story.
the desi jugaars will ruin the paint , once that happens it might not be possible for even a detailer to fix the damage
dont want to ruin the body
share a pic of the elfy on the paint
i once was in same situation. rubbed with petrol dipped cloth and then with a cloth dipped in surf and water. it took so much effort and i was becoming tired so i used flat head screw driver too. this made some little scratches but made the job easier. at last was able to get rid of it
