#101 (permalink) |
1,192 days old at PW
Dear seller.
I have also been observing that you post the same car for sale after some time again. Did you ever tried to see why you are car is still on the sale ? I do think that your asking price is too high. . Regards, |
#103 (permalink) |
Some info about it
table cellpadding=1" cellspacing=1" width=623" tbody GENERAL Body type Sedan Drive FF Transmission 4 speed automatic Displacement, cc 1498 Frame GF-AE110-AEPEK(L) Price of new car, thousands yen (Tokyo area) 1582 (~$13100) SPECIFICATION (SPECS) EXTERIOR Exterior dimensions (LxWxH), mm 4315 x 1690 x 1385 Interior dimensions (LxWxH), mm 1830 x 1425 x 1165 Wheel base, mm 2465 Treads (F/R), mm 1470 / 1460 Ground clearance, mm 150 Curb vehicle weight, kg 1060 Gross vehicle weight, kg Seating capacity, persons 5 Doors number 4 Min.turning radius, m 4.8 Fuel tank capacity, l 50 ENGINE Displacement, cc 1498 Engine model 5A-FE Max.power (Net), kw(PS)/rpm 100 ps (73.55 kw) / 5600 rpm Max.torque(Net), N*m(kg*m)/rpm 14.0 kg*m (137.29 N*m) / 4400 rpm Power density 10.6 Engine type Serial 4 cylinder DOHC16 valve Engine information Fuel system EFI (electronic fuel injection) Turbocharger No Fuel type Unleaded regular gasoline LEV system (Low emission vehicle) No Compression ratio 9.8 Bore, mm 78.7 Stroke, mm 77 Final gear ratio Fuel consumption at 10-15 modes, l/100km 6.8 Fuel consumption at 60 km/h, l/100km CHASSIS / TRANSMISSION Power steering Yes Tires size, front 185/65R14 82s Tires size rear 185/65R14 82s Braking system, front Ventilated disk Braking system, rear Drum (leading/trailing) Suspension system, front Strut type coil spring Suspension system, rear Strut type coil spring (stabilizer attaching) EQUIPMENT EXTERIOR EQUIPMENT Sunroof / Moonroof Option Front fog lamp Option Rear fog lamp Not Present Xenon headlight (Discharge lamp) Not Present Projector headlight Not Present Rear wiper Not Present Front spoiler Option Rear or roof spoiler Option ABS (Antilock brake system) Present TCS (Traction control system) Not Present LSD (Limited slip differential) Not Present Privacy glass Not Present UV cutting glass Present Aluminium wheel Option INTERIOR EQUIPMENT Air conditioner Full automatic Wood panel Present Cruise control Not Present Centralized door lock Present Power window Present Steering wheel telescopic Not Present Steering wheel tilt Present Leather steering wheel Not Present Power front seat Not Present Power rear seat Not Present Leather seat Not Present Falling down type rear seat Not Present Child seat fixed with seat belt Present Rear ELR3 point seat belt Present Front seat pretensioner seat belt Present Fourth limited front seat belt Present Side impact bar Present Airbag (Driver) Present Airbag (Passenger) Present Airbag (Side) Not Present Audio deck AM/FM radio equipped cassette player CD-player Not Present Car navigation system Option /tbody /table
__________________
speed thrills but kills {Check out my ride} http://www.pakwheels.com/ridedetails.asp?CarID=4811 |
| Bookmarks |
| Thread Tools | Search this Thread |
