Got a must have for sale for anyone who is looking to add a 5.1 entertainment system in their car.
Alpine MRA-D550
5-channel Digital Theater car amplifier
60 watts RMS x 5
Multi-channel DVD sound is an awesome experience in your home ? now imagine how great it'll sound in the enclosed space of your car. Wonder no more ? the MRA-D550 Digital Theater Amplifier, controlled by a compatible Alpine in-dash stereo, will anchor your multi-channel car audio/video system, delivering deep, realistic sound from your recordings that you have to hear to believe.
The amp's all-digital design delivers 60 watts to each of five channels, supplying the front, rear, and center channel speakers of your system with plenty of clean power. Two inputs allow you to hook up multiple digital sources (like a DVD player or a game system) while built-in processors convert the digital info into surround sound. Built-in Dolby Pro-Logic II processing does a great job of enhancing the sound of your standard CDs.
The MRA-D550's heavy-duty internal components produce rock-solid power, and extra-large capacitors deliver additional current when needed to fuel musical peaks. A unique circuit design greatly reduces internal noise, keeping the signal clean for better performance from your speakers. Alpine's Bass Engine tone adjustments allow you to fine-tune the sound to perfectly match your vehicle. You can control the MRA-D550 with an Alpine GlideTouch CD player, for touchscreen control right from the front seat.
Highlights:
- 5-channel Digital Theater amplifier
- 60 watts RMS x 5 at 4 ohms
- Dolby Digital, DTS, and Dolby Pro Logic II processing built-in
- two optical digital inputs
- MOSFET power supply
- CEA-2006 compliant
- Ai-NET capable with compatible Alpine receivers
- Bass Engine? features:
- variable center-channel crossover (20-800 Hz in 1/3 octave steps, 12/18/24 dB per octave)
- variable front, and rear high- and low-pass crossovers (20-400 Hz in 1/3 octave steps, 6/12/18/24 dB per octave)
- variable subsonic filter (20-50 Hz in 1/6 octave steps)
- subwoofer phase control (0/180 degrees)
- time correction adjustment (0-10 mSec.)
- 17-band parametric EQ (five bands for front, rear, and center, two bands for sub channel)
- sub channel preamp output (20-200 Hz low-pass filter, 6, 12, 18, or 24 dB/octave)
- STAR Topology (minimizes internal noise and prevents ground interference)
- detachable front cover
- blue power LED
- fuse rating: 20A x 2
- 8-gauge power and ground leads recommended ? wiring and hardware not included with amplifier
- 13-11/16"W x 2-9/16"H x 10-5/8"D
Alpine MRA-D550 5-channel Digital Theater car amplifier 60 watts RMS x 5 at Crutchfield.com
Alpine DVA-7899J pre
One of the top high end series Player from ALPINE
Standard comparable with F1 status.
Can read DVD, can play DVD mode, tv screen must go additional.
Not much info on net for this but it plays dvd and mp3. and it has AI net and optical outputs so it can be used with the amp above. dont the exact condition of the lens as i only had an original audio cd to check it and it worked fine on that.
Accessories:
Ai net cable
Optical cable
Remote (without cell cover)
Demand: whole setup for 19,000 Rs (amp alone is worth 250$ in used on ebay)
PRICE REDUCED
Condition: as seen in the pics
Payment method: Bank transfer or easy paisa (u pay the easy paisa fee)
Delivery charges: To be paid by the buyer
Negotiation margin: slightly negotiable
Contact: 0302 8425065
