Forums Home Members List Social Groups Search Today's Posts Mark Forums Read
Go Back   PakWheels Forums > Technical Forums > Car Entertainment / Electronics / GPS Navigation
Car Entertainment / Electronics / GPS Navigation In car entertainment requirements, from standard fitment systems and radios to multimedia upgrades and satellite navigation systems.
Old 07-11-2009, 10:12 AM   #1
jz
2,098 days old at PW
Default wt sort of amp to go for in 9k?
Aslam o alikum guys
im looking to buy an amp in about 9k price range.currently im using a crunch 500w 2channel amp n n im not satisfied with it,running a 12inch sub n a paire of jvcs with it.
before that i had a audiobahn 1600w 4 channel amp which i sold n made a stupid mistake.im planning to sell my crunch but the question is what amp should i go for???
the problem im facing is the sound gets distorted at high volumes
how wud u rate this crunch amp keepin in mind that ive to run,
a 12inch kenwood sub n a pair of 6 x 9 speakers
any suggestions would b welcomed
these r the stuff im using for the time being + 2 pairs of door speakers which r directly connected to the player
__________________
performance plugs for sale >> www.pakwheels.com/forums/engines-powertrain-parts/97983-performance-oem-plugs-sale
Your fate is what u make of it.
jz is offline   Reply With Quote
Old 07-11-2009, 10:50 AM   #2
1,200 days old at PW
hmm ...
this amp not bad .. but the problem is that u r not using it correctly as its 2 channel use it for speakers or use it for woofer..
well i would suggest either buy another 2 channel amp and use that for speaker and use the current for woofer by putting it on LPF... or wise versa..
or exchange ur amp with a good quality 4 channel amp and use 2 channel for speakers and a bridge connection for woofer...
__________________
scorpion80 is offline   Reply With Quote
Old 07-11-2009, 12:17 PM   #3
1,352 days old at PW
Quote:
Originally Posted by scorpion80
hmm ... this amp not bad .. but the problem is that u r not using it correctly as its 2 channel use it for speakers or use it for woofer.. well i would suggest either buy another 2 channel amp and use that for speaker and use the current for woofer by putting it on LPF... or wise versa.. or exchange ur amp with a good quality 4 channel amp and use 2 channel for speakers and a bridge connection for woofer...
Agreed.
or
u can buy a seperate mono amp for the sub.
__________________
An army of sheep led by a lion is better than an army of lions led by a sheep-(Alexander)
stj174 is offline   Reply With Quote
Old 07-11-2009, 12:41 PM   #4
1,267 days old at PW
i c a sony pre ..which i think it has no crossover or a sub out wid basic options ...start wid a good powerfull headunit always ....
secondly ur getting the mids in ur sub becoz in ur setup speakers and sub both are running on full crossover u cannot tune ur speakers to hpf and sub to lpf at a time....so find out a 4 channel amp if u r not intended to change the sub....but if u want to add another sub or any SPL then buy a heavy 2 channel amp or a D class mono
__________________
Doing the box designs.Pm me for details
Maggi is offline   Reply With Quote
Old 07-11-2009, 02:19 PM   #5
jz
@ maggi
so the answer is a good 4 channel amp?cuz i intend to run just 1 sub n 2 speakers,nothing more
any good amp that u can suggest me ???
i m running the amp on flat not hpf or lpf
__________________
Old 07-11-2009, 02:21 PM   #6
jz
or another 2 channel amp
__________________
Old 07-11-2009, 02:24 PM   #7
681 days old at PW
maggi have some MTX mono block amplifier
contach him
__________________
Trying to be real slow turn up the bass real low get the sounds that head low tune the channel of EXO gonna take to the level where speaker streams ,ready to rattle up the box
geforce is offline   Reply With Quote
Old 07-11-2009, 03:12 PM   #8
jz
@ gefore
maggi suggested me to eigther go for another 2 channel amp or a 4 channel,id go for a single 4 channel amp
__________________
Old 07-11-2009, 04:37 PM   #9
1,902 days old at PW
if u get a mono amp now u can than easily use a bigger woofer in the future (trust me one day u will want a bigger woofer )
if u get a 4ch, what will u do with ur current 2ch amp? if i were u i wud get a mono instead of 4 ch. cause u both 4ch and mono wud cost around the same
__________________
The SUB will do what the BOX tells it to do!
Lafafa is offline   Reply With Quote
Old 07-11-2009, 04:47 PM   #10
if u want to keep these type of subs wid u then ..otherwise make the necessary changes
__________________
Old 07-11-2009, 05:06 PM   #11
526 days old at PW
go for a AUDIO BANK 2200 watts
or
SOLID AUDIO 1600 watts.........
definately will get 1 in the range..........
deathracer is offline   Reply With Quote
Old 07-11-2009, 05:13 PM   #12
1,491 days old at PW
@scorpion80
100% agree
__________________
i Walk a Different path
spangle is offline   Reply With Quote
Old 07-11-2009, 05:14 PM   #13
jz
Quote:
Originally Posted by deathracer
go for a AUDIO BANK 2200 watts or SOLID AUDIO 1600 watts......... definately will get 1 in the range..........
which model can i get of solid audio in that price?
__________________
Old 07-11-2009, 05:16 PM   #14
jz
Quote:
Originally Posted by Lafafa
if u get a mono amp now u can than easily use a bigger woofer in the future (trust me one day u will want a bigger woofer ) if u get a 4ch, what will u do with ur current 2ch amp? if i were u i wud get a mono instead of 4 ch. cause u both 4ch and mono wud cost around the same
since i dnt have budget for a biger sub id get the amp changed first,can hardly change the amp
__________________
Old 07-11-2009, 05:17 PM   #15
jz
Quote:
Originally Posted by spangle
@scorpion80 this amp not bad .. but the problem is that u r not using it correctly as its 2 channel use it for speakers or use it for woofer.. well i would suggest either buy another 2 channel amp and use that for speaker and use the current for woofer by putting it on LPF... or wise versa.. 100% agree
agreed bro
__________________
Old 07-11-2009, 05:21 PM   #16
681 days old at PW
mono can handle your sub very well
9.5K
kenwood 9103
300wrms @ 4 ohms
500Wrms @ 1 ohms
MTX Thunder Series 600w
400wrms @ 4 ohms
600Wrms @ 2 ohms
1ohms stable
ask maggi
for mtx
__________________
Old 07-11-2009, 05:26 PM   #17
jz
kenwood 9103 wil do the job for me,i just wnt a good 4 channel amp
__________________
Old 07-11-2009, 05:27 PM   #18
526 days old at PW
yar i dont know exactly coz a man in pakwheels was selling amplifier SOLID AUDIO
and he was demanding 11k..............!!!!!!!!!!!!!!!
Old 07-11-2009, 05:28 PM   #19
jz
^^ tats outa my range ^^ id wait to buy the kenwood amp geforce mentioned
__________________
Old 07-11-2009, 05:30 PM   #20
jz
@ geforce
bro do u thnk tat kenwood 9103 wud handle my speakers wel?or wud i need to get heavier speakers?
cuz i jus wana run a pair of 6x9s n a sub,nothing more
__________________
Reply
Bookmarks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are Off
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
