Page 3 of 4 FirstFirst 1234 LastLast
Results 41 to 60 of 64
Thread: Help me build high quality SQ system for my Honda Civic 2005
    NemesisPRO's Avatar
    Aug 2010
    32
    25
    Default Help me build high quality SQ system for my Honda Civic 2005
    Hi everyone. I am building high quality SQ Audio setup for my Honda Civic 2005 VTI ORIEL Prosmetic UG. I need very superior quality clean sound with each beat distinguishable and audible. I want balanced center sound stage with rear fill and front stage like surround experience. Hardware configuration should be SQ focused yet should have potential to produce good heart punching bass if required. Bass level should be configurable from heard punching big bass to pure SQ bass.
    Current Configuration:
    Head Unit: JVC KW-AVX826 EXAD (http://www.jvc.co.nz/assets/pdf-brochure/KW-AVX826.pdf)
    Amplifier: Solid Audio F-45 900Watts 4-Channel
    Solid Audio XT-804 1600Watts Extreme Series 4-Channel (Spare Not in Use)
    Rear Speakers: Sony Explod
    Front Speakers: Company Fitted
    Woofer: Pioneer 307 D2
    I will update my current setup in two stages.
    I want to build the system in two stages because of money coming in phases. I had an option to build good system now and upgrade it later or build incrementally. First option is good in that I get full working setup quickly but it will not be best setup and vice versa. I will give you budget for both approaches. And you guys can tell me what to do.
    Budgets:
    Item / Quick Budget / Stage Wise Budget
    Amplifier / 25000 / 25000
    Mono Amplifier / 0 / 25000
    Woofer / 0 / 20000
    Front Components / 15000 / 45000
    Rear Component/Speakers / 0 / 20000
    Wiring Kit / 5000 / 7000
    Sound Deadening / 0 / 6000
    Total / 45000 / 147000 ~ 150000
    I think incremental setup feels logical choice. But I can’t go without front component right now so I have to pick some component to live with till I am ready for big ones. But what do you think?
    Budget: Stage 1
    Amplifier: 25000/- some recommendations I got JL Audio A4300, Pioneer PRS-D4100F
    Front Speakers: 15000/- some recommendations I got Pioneer TS-D720C, Rockford Fosgate T162S
    Rear speakers: same which is fitted now i.e. Sony Explod
    Woofer: same as fitted now i.e. Pioneer 307 D2
    Mono Amplifier: will use either of available amplifiers i.e. Solid Audio F-45 or XT-804 to run woofer.
    Wiring Kit: 6000/-
    Budget: Stage 2
    Rear Speakers: 20000/-
    Woofers: 20,000/- recommendations I have Rockford Fosgate P3
    Mono Amplifier: 25000/- may be Pioneer PRS-D1100M
    Front Components: 45000/- may be Focal 165KRX2.
    Sound Deadening: 6000/-
    Wiring Kit: 7000/-
    I want to know will the first stage work in proposed combination till I am ready for 2nd stage up-gradation.
    I would request feedback from privileged members of PW community especially @enerlevel, @smartboy, @splfanatic,@stj174, @qureshi498, @geforce, @Lafafa.
  2. #41
    NemesisPRO's Avatar
    Aug 2010
    32
    25
    Quote Originally Posted by Lafafa View Post
    good luck...ur system will sound superb if you go through with these plans..the processor will cost you north of rs25-rs30k !
    by the way, single w12prs sub wont hit ur chest or go loud enough to impress ur friends. however, two of those (wires at 1ohms) might do the trick. the d1100m prs amplifier is 1 ohm stable and gives 600rms (both at 1ohm and 2ohms)...so that might also be more than enough for those subs...
    however, serious sound damping is in order!!
    Thanks man! but what about the confusions
    JL or PRS amp
    and Sub w12prs or rf p3
    and by two subs will it be sql level bass or spl?
    But I, being poor, have only my dreams. I have spread my dreams under your feet.
    Tread softly because you tread on my dreams.
  3. #42
    mohsin129's Avatar
    Oct 2009
    24
    753
    Quote Originally Posted by NemesisPRO View Post
    yup but with cross of @lafafa system
    STJ also has the Pioneer PRS-D4100F in his other car...so basically thats that
    best of luck...if u go with their chosen products the result is indeed gonna be worth it...
    Pioneer 5100UB~JBL P650c~Jl 12w3v2(2)~SS TRA 680.4~MTX Thunder 81000D~1/0 gauge Wiring
  4. #43
    959
    959 is offline
    959's Avatar
    Jan 2007
    30
    3,121
    Sir
    You are going for half blooded system, that DSP will take you no where with that JVC A/V system.
    Pioneer PRS is better then JL.
    W12PRS is two times better then RF P3, team Pioneer is using it for 3 years now in SQ competition.
    1 W12PRS is better for pure SQ, Type and JL W6 are better for SQL, you can also employ 2 x W12PRS if you have the budget.
    Regards
    Readers are Leaders.
  5. #44
    NemesisPRO's Avatar
    Aug 2010
    32
    25
    Quote Originally Posted by 959 View Post
    Sir
    Regards
    can you please elaborate on jvc A/V KW-AVX826 by giving exact issue with it. have you gone through its specs? give me the metrics you think is out of order for such combination.
  6. #45
    NemesisPRO's Avatar
    Aug 2010
    32
    25
    @lafafa whats you take on JVC KW-AVX826 Head Unit with proposed system. please go through the specs and ellaborate. here are the specs http://www.jvc.co.nz/assets/pdf-brochure/KW-AVX826.pdf
    thanks.
  7. #46
    959
    959 is offline
    959's Avatar
    Jan 2007
    30
    3,121
    Sir
    Why do not you compare yourself.
    Alpine Electronics of America, Inc. - CDA-9887
    DEH-P88RS-II Reference Series CD Tuner - Pioneer Car Stereo - Digital Media Receiver
    If you love JVC brand this one is the better one:
    JVC Middle East/Africa/CIS Consumer Home Electronics Dubai, UAE. HDD Camcorder, Audio, Car Audio, LCD
    Secondly you are paying too much for Components, there is no need to buy 1,000 $ components unless you can collaborate and position them and set the crossover network which I doubt anyone can do without the equipment.
    These Alpine would be more then sufficient and they will perform better out of box unless you have a LEXUS LS 600.
    You should compare them both out of box and listen them before buying, every expensive thing is not better.
    Thirdly drop that center stage, seriously.
    Regards
  8. #47
    NemesisPRO's Avatar
    Aug 2010
    32
    25
    Sir
    I you love JVC brand this one is he better one:
    Secondly you are paying too much for Components, there is no need to buy 1,000 $ components unless you can collaborate and position them which I doubt anyone can do without the equipment.
    Regards
    still i dont see any difference. which feature are you comparing it to?
    here are JVC specs
    Help me build high quality SQ system for my Honda Civic 2005 -128720
    and here are Pioneer Specs:
    Help me build high quality SQ system for my Honda Civic 2005 -128721
    can you please elaborate?
  9. #48
    smartboy_am's Avatar
    Oct 2008
    23
    4,600
    9 Post(s)
    i am still on for jl, and for noman (stj) he is planning to change that prs to phoenix gold....
    NIKON D5100 , AF-S NIKKOR 18-55mm f/3.5-5.6G VR kit lens
    Team DEKA
  10. #49
    Lafafa's Avatar
    Jun 2005
    32
    3,089
    8 Post(s)
    @poster...
    959 has explained things nicely. yaar you cannot use that pioneer 5.1ch processor with that JVC unit that you have. you will need a pioneer dvd unit for that...
    and only go for the 5.1 processor if you are going to use 5.1 dvd movies and 5.1 recorded music DVDs...if ur only going to be listening to MP3s, than there is no point of these...
    as for the woofer, 1 w12prs sub is enough. it is an SQ competition woofer. ... if u want more loudness (which is not required in SQ)...than install two of those subs. but than dampen ur boot properly...
    another important thing, 300rms for ur sub is more than enough in ur SQ install when you have 80-100rms components. otherwise ur entire soundstage will be dragged down by ur woofer...
    and if ur planning to make an SQL setup - than dont buy $1000 components and highend amplifiers. midrange stuff is more than sufficient....
    as for the amplifier, well yar it is personal preference. i love the prs-4100f. and it was in my budget at the time i bought it, and its very power efficient. i love power efficient amps/subs (i dont plan on upgrading my stock battery in corolla). and the sound of this is amazing...although i have yet to test it on my focal KR2s...so i cant say much...havent heard the JL amp so cant comment much on that. maybe you should read reviews...that will help you....
    by the way, JL is more popular for their subwoofers, just like focal is for their components....
    The SUB will do what the BOX tells it to do!
  11. #50
    Lafafa's Avatar
    Jun 2005
    32
    3,089
    8 Post(s)
    Quote Originally Posted by smartboy_am View Post
    @ poster, if this is the case...u might want to contact STJ and buy his prs amplifier - might even get a decent deal
  12. #51
    stj174's Avatar
    Dec 2006
    35
    2,809
    59 Post(s)
    3 Thread(s)
    Perhaps... But i will never trade that PRS amp with a JL A-Series (entry level) amp.
    BTW i am also planning about changing my PG amps with MACs, but thats just planning but it never happened ....!
    Ragar Dey!
  13. #52
    Lafafa's Avatar
    Jun 2005
    32
    3,089
    8 Post(s)
    sir...ab aap ko PG amps bhi nahi pasand kya??!!
  14. #53
    stj174's Avatar
    Dec 2006
    35
    2,809
    59 Post(s)
    3 Thread(s)
    Sir i love the PGs .... but MAC is MAC. Its not that i am going to buy one in the near future, just a thought
    Ragar Dey!
  15. #54
    Oct 2008
    23
    4,600
    9 Post(s)
    Quote Originally Posted by stj174 View Post
    yup i didnt said ur amp is not gud, it's also one hell of a technolgy, plz dont mind what i said earlier..
    Team DEKA
  16. #55
    Oct 2008
    23
    4,600
    9 Post(s)
    Team DEKA
  17. #56
    Lafafa's Avatar
    Jun 2005
    32
    3,089
    8 Post(s)
    GM series by pioneer is average at best. nothing compared to the PRS family.
    The modern pioneer stage 4 PRS series are superb. very high end amps. even the stage 4 class FD 2ch and 4ch amps are very competitive. they are even more expensive than JL, alpine amps etc...and those are being used in SQ competitions.
    sadly those are not available in pakistan yet..
  18. #57
    Oct 2008
    23
    4,600
    9 Post(s)
    Thankx farhan. Yar i just found so thought of sharing.yeah the gm series is no where near prs series, but the gm series have also been upgraded now. The new ones are also class fd, same as prs.but prs takes the lead between them
    Team DEKA
  19. #58
    stj174's Avatar
    Dec 2006
    35
    2,809
    59 Post(s)
    3 Thread(s)
    GM is no match for the PRS, they are totally of the different breed. BTW i have tested PRS along with the all famous Zapco Reference amp. I have found the PRS to be equal to the Zapco (if not better)
    Pic:
    http://assets.pakwheels.com/forums/2...S-family-2.jpg
    http://assets.pakwheels.com/forums/2...S-family-1.jpg
    So dont keep any doubts about the sound quality of the PRS amp
    Ragar Dey!
  20. #59
    Lafafa's Avatar
    Jun 2005
    32
    3,089
    8 Post(s)
    and zapco amps are considered SQ amps...from what i have read...
    and i admit ppl say class AB is better than class D...but more and more people are adopting class D now....so technology hai bhai...DSPs and highend OP amps ka zamanaa hai...PRS amp has very expensive Linear Technology op amps in its circuitry. their op amps alone cost 150-200 bucks ...those PRS amp are sold for around $500 bucks in usa...they are not a joke
    try to get stage 4 PRS amps..they are hot!
    by the way, why u want 4ch amp in the first place??
  21. #60
    mani1's Avatar
    Mar 2006
    28
    4,524
    any latest updates? is your setup complete?
Similar Threads
  1. build honda civic 2001
    By p0p in forum Vehicles / Bikes
    Last Post: 05-04-2009, 02:31 AM
  2. High School Students Build 2,843 MPG Car
    By Alkazar in forum News / Articles / Driver Education / Safety
    Last Post: 26-04-2008, 03:38 PM
  3. Honda Accord wins award for ‘High Quality Design’
    By maya12 in forum Cool / Classic Cars / Latest
    Last Post: 24-03-2008, 04:57 PM
  4. new bmw m5 pics high quality
    By spiderman in forum Performance / Modification / Tune Up / Preventive Maintenance
    Last Post: 11-04-2006, 11:43 PM
