Hi ,Pak wheelers ,Finally i was able to buy a used infinity amp
with the following specs
[h=2]Product Highlights:[/h]
- 4-channel car amplifier
- 111 watts RMS x 4 at 4 ohms (139 watts x 4 at 2 ohms)
- 278 watts RMS x 2 bridged output at 4 ohms (4-ohm stable in bridged mode)
- front and rear variable high-/low-pass filters (32-320 Hz, 12 dB/octave)
- variable bass boost (0-12 dB at 50 Hz)
- MOSFET power supplies
- CEA-2006 compliant
- Tri-way capable (Tri-Way crossover required)
- preamp- and speaker-level inputs
- preamp outputs
- 8-gauge power and ground leads with a 60A fuse recommended ? wiring and hardware not included with amplifier
- fuse rating: 30A x 2
- 16-3/8"W x 2-11/16"H x 12-1/8"D
- Now my Question is Can i run a Pioneer D4 or ,Infinity Reference 1250, or ,JBL gt5-15 along with 2 6.5 Front components and two 6*9 rear speakers or i have to purchase a mono amp or i have to run two rear speakers
- from PRE , which sub will work better with this amp ,for sub i am looking for best of both worlds bass as well as sound quality ? if you guyz can recommend good 6*9 speakers for a SQ setup that will be appreciated , help me out ,Thank you in advance
