Brothers,
I need advise about the wiring kit that i need to replace for my below setup. Also i will post some pics of my current settings on Head Unit to give an idea how to make it sound more better. I have put some picture of head unit settings and options to manoeuvre. Suggestions welcome
I need help for
Currently it has 8 gauge wiring kit installed which one shall i go for ?
How do i wire it with amp ?
What settings will b best on heading ?
Head Unit: Pioneer Avic F40BT
It is powering the stock set of speakers.
AMP: In Phase IPA1601 1600 Watts 2 Channel Amplifier
- 300w RMS x 2 @ 4ohms
- 400w RMS x 2 @ 2ohms
- 1600 watts max music
- Regulated power supply
- MOSFET power supply
- Tri Mode operation
- Oversize Power Tranformer
- Bipolar Output devices
- Variable cross over (high/low pass)
- Dimensions (L x W x H) 380mm x 250mm x 55.5mm
- Bass Boost
- Variable gain adjustment
- Thermal protection
- Overload protection
- 2ohms Stable
- Variable Subsonic Filter 20Hz- 50Hz
- High pass filter frequency 80Hz - 1.2kHz
- Low pass filter frequency 50Hz - 250Hz
- RCA output for amplifier linking
SUB: Rockford Fosgate PL2-110
- Single 10" Punch Stage 2 Woofer
- 4 ohm SVC
- Pre-loaded woofer in a vented subwoofer enclosure
- Utilises proprietary high-flow, low noise ports
- High current binding posts
- 5/8" MDF Construction
- H 13.5" x W 17.25" x L 16"
