I have been using the PW from quite some time to get the valuable information about people experiences with different audio gears people have used and their reviews.Today i created an account as i seek your advice from your experiences.
Before moving on to my queries, i intend to give brief overview of what is installed in car and what i like to add.
Front components are Infinity 6030Cs
Rear coaxial JBL GTO938
Amp is some unknown Korean brand which i need to discard.
Now i intent to add a sub woofer and replace the amp. I have shortlisted a Sub and an Amp, which i have found available in market. Sub is JBL P1224, in a sealed box of 1CuFt internal volume and Amp is Pioneer GM D9604.
Now comes the part that im unable to sort out. I intend to use one Amp that is Pioneer GM D9604 for front stage and sub. Amp specs are
4 x 100 W (20 Hz - 20 kHz)
4 x 150 W (1 kHz / 2Ω)
4 x 125 W (1 kHz / 1Ω)
2 x 300 W (1 kHz / 4Ω bridge)
2 x 250 W (1 kHz / 2Ω bridge)
GM-D9604 Pioneer - Amplifier, Amp - Car*Entertainment
where as components are 90RMS. These are 2 Ohm drivers. P1224 is 400 RMS watts (200 watts per coil). 4 ohm drivers
Now,
Can i run the amp using 2 channels from components at 2 ohm and bridge remaining 2 channels for sub at 4 ohm?
Will the amp be able to support both components and subwoofer. In above configurations will amp give 150RMS to components and 300RMS to woofer.
Pl note that amp and sub is still to purchase, so suggestions are welcomed for them also.
