Salam all. Hope everyone's blessed month is going great.
I have a kenwood x7016 unit.
For the last month or so it won't switch off - nothing happens on the long press of the SRC button. It also won't let me select any source; if it is on standby it will remain on it until I plug in a USB flash drive. On doing that it shifts to playing files from the USB but then I can't skip to the next track or go to the previous track; pressing the next-track and previous-track buttons does nothing. I can go into menu and select a new track from there, just not from the buttons on the front faceplate.
I also found out that I can't change xover settings - they're stuck on the last settings I had before this problem came up, just like the HU's clock which I can't change either (its date I can still set). I try to recall a blank preset of DSP settings, which changes the xover settings to blank, but I still can't set them myself.
The interesting and nerve wracking thing is, I tried resetting the unit using the reset button on the main unit, even disconnected the wiring harness behind its back, but the old xover settings come right back (date & time do reset and demo-mode comes on, but everything else remains same).
Frustrated and looking for wheelers' suggestions & expertise.
