Dear you don't even fulfill the eligibility criteria for almost all the universities,minimum 60% is required to apply, so you have only IIUI as one of the best options(here eligibility criteria is minimum 50%)...you don't need to worry or regret,forget the past, and ICS is best,just prepare the entry test of IIUI and also apply to bsse,bscs,along with bba,,,each faculty has different tests(bsse,bscs have same they will adjust you in any faculty depending upon your entry test result)...for further assistance reply and ask the questions you want to answer...JAZAKALLAH
Sent from my Lenovo A5000 using PW Forums mobile app
