Community Forum Actions
Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By drift222
Thread: Relation between Bars and Kgs
    SmilingTulip's Avatar
    Mar 2012
    24
    Default Relation between Bars and Kgs
    What's the relation between Bars and Kgs? Calculations show the other results while filling some 6-7 Kg CNG shows 200 bar on the Pressure gauge.
    capsat's Avatar
    Apr 2006
    4,431
    2 Post(s)
    Lightbulb
    Bar is specific volumetric unit of air pressure - kilogram is weight volume unit of any mass which can be contained in a vessel
    what WE see on CNG station pressure meters (BAR in red) in black it is 200- 230 PSI
    14.503 PSI (pounds per sq in) = 1 BAR - - 1 bar <= 0.98 kilograms
    MORE
    when such high pressure is released in cylinder it starts to store when capacity is topped up the pressure sensor in dispenser cut-off the pressure stops the discharge and meter comes to halt.
    Please read --> http://www.pakwheels.com/forums/site-feedback-suggestions/181978-attention-mods
    drift222's Avatar
    Oct 2011
    29
    462
    3 Post(s)
    bar and kg are two altogether different dimensions. bar belongs to pressure and kg to mass.
    however while filling CNG more the bars on dial more the kg will be filled in cylinder.
    waseef likes this.
    Speed thrills but kills
    shabbir.1's Avatar
    Jul 2010
    372
    3 Post(s)
    Quote Originally Posted by drift222 View Post
    Correctly said..... There is no direct relationship between "BARs" and "Kgs". The more you can compress the gas the more you can fill in the cylinder.
    The CNG dispenser actually measures the mass of the gas with the help of mass flow meter and it shows this value on its main display and the pressure gauge actually shows how much you can fill in the cylinder. If suppose at 150 Bar pressure 4 Kgs of gas can accomodate in the cylinder then at 200 Bar it may rise to 6 Kgs.
    Regards
    a_n_memon88's Avatar
    Jun 2010
    24
    1,307
    6 Post(s)
    4 Thread(s)
    I dont know whether there is any relation between bar and kgs or not, but through my experience of CNG filling and consumption and continuous monitoring of guages I have come to a conclusion that in my cars CNG cylinder a kg equals 23 bars pressure. So when there is 180 bar pressure nearly 8 kgs or under 8kg gas fills in when there is 200 bar pressure nearly 8.6kg gas goes in and when there is 220 bar pressure than 9+kg gas goes in. I do not claim that these calculations are universal truth but they are spot on for my car.
    Xulfiqar's Avatar
    Aug 2003
    Houston
    34
    12,879
    140 Post(s)
    12 Thread(s)
    you are confusing two different units of measure. The volume of gas is also affected by temperature.
    ZRS - Zulfiqar Racing Systems ..... PROFESSIONALS at WORK at CRACKWHEELS.COM
Similar Threads
  1. Relation btw battery and cng
    By shaikh229 in forum Electrical / Wiring / Battery / Lights
    Last Post: 02-06-2011, 11:40 PM
  2. Help me about Battery & A/c Relation!!!
    By abbasaliabbasi in forum Electrical / Wiring / Battery / Lights
    Last Post: 16-08-2010, 05:15 PM
  3. Brake - AC Relation
    By Scorpion1983 in forum Wheels / Tyres / Suspension / Brakes / Steering
    Last Post: 11-05-2009, 04:10 PM
  4. strut bars, anti-sway bars.
    By tauseef in forum Body Work / Interior / Paint / Glass / Appearance
    Last Post: 16-10-2005, 04:33 AM
