Community Forum Actions
Results 1 to 7 of 7
Thread: CNG car doesn't start on petrol
    freakridemaniac's Avatar
    Feb 2007
    3,687
    Question CNG car doesn't start on petrol
    AOA
    Dear fellow members I need help in this situation. I have a Mehran which I mostly use on CNG. However due to the un predictable situation in our city, I sometimes need to run it on petrol. The problem is it doesn't start right away. I need to turn the key again and again due to which a constraint is developed on the battery. Some people say this problem is because the carburetor becomes dry on CNG and when you have to switch to petrol open the carburetor and put some petrol there and then start it. Is this true? Can this problem be overcome by using a stronger fuel pump or better spark plugs?
    Kindly help regarding this matter, thank you.
    Petrol head.
    capsat's Avatar
    Apr 2006
    4,431
    2 Post(s)
    if the problem is starting engine on petrol you need to check for fuel pump, remove outter line from pump put it in an empty bottle crank the engine few time & see if fuel pump is squirting petrol in the bottle, if it is then place the line back in its place & adjust the ignition timings for petrol run.
    Please read --> http://www.pakwheels.com/forums/site-feedback-suggestions/181978-attention-mods
    Feb 2007
    3,687
    Fuel pump is doing its job. How am I supposed to adjust the ignition timings? :s
    Petrol head.
    argtr65's Avatar
    Dec 2008
    47
    1,067
    8 Post(s)
    Carburetor requires cleaning.
    Never loose hope in life,every step gives u something.
    Feb 2007
    3,687
    Okay. I forgot to mention that I tried to switch to petrol after using it on CNG for like 4 months... I went to a mechanic who did the job for me. I drove it on petrol for 10 days and then drove it on CNG for a week and then it still won't convert at a click of the switch...
    Petrol head.
    Feb 2007
    3,687
    I need someone to educate me about this issue, please.
    Petrol head.
    Feb 2007
    3,687
    Someone?
    Petrol head.
Similar Threads
  1. car does not start on petrol
    By hammad5 in forum Engine / Transmission / Powertrain
    Last Post: 09-02-2012, 10:53 PM
  2. Ar wont start on petrol
    By bmwlover in forum Engine / Transmission / Powertrain
    Last Post: 09-12-2010, 02:34 PM
  3. Mehran doesn't start
    By mansoor531 in forum Electrical / Wiring / Battery / Lights
    Last Post: 27-08-2010, 02:49 PM
  4. My Car's Radiator Fan doesn't start when AC is ON'
    By fehaan in forum Engine / Transmission / Powertrain
    Last Post: 04-11-2008, 02:31 PM
  5. My car wont start in petrol
    By reddevils in forum Engine / Transmission / Powertrain
    Last Post: 12-06-2007, 12:16 PM
