AOA dear pakwheelers hope u all are doing good strange thing happened yesterday went for isha prayer parked the car its was fine car is honda city i-dsi 2007 after prayer when i was coming back home the car refused to start on both cng/petrol checked all the fuses there but every thing except a 15amp fuse was okay luckily my uncle was also there he had a spare in his car replaced that there but no help so then asked my uncle to tow the car home after coming back i decided to diy it opened the fuse box found some burnt wires of cng switch 4 of the petrol cng power and ground managed to repair that and the lights on the switch came back on but still no luck it was not starting on any of the fuel so then i decided to open the wires of advancer and injectors there i found the red wire that was burnt replace and finally some thing good happened it started and is running fine now but will re doing the wiring i noticed that there is no connection to four point of the advancer it is tomasetto lovato new cip plus (not new cip 4 plus) which was installed back in 2008 and is working fine till date car sometimes give CEL on cng and sometimes it does not respond well on cng in 1st and 2nd gear
This is the installed advancer+emulator These four points have no connection wires are cut from the connector setting of the buttons
experts ????
