Old 01-07-2009, 01:23 AM   #1
hammadmajeed
677 days old at PW
Default Automatic switching between cng and petrol
Lately, I am getting this weird problem of automatic switching of the car from cng to petrol and instantly back to cng. There is no fixed pattern of the occurance of this problem.
Any idea what may be the problem ?
hammadmajeed is offline   Reply With Quote
Old 01-07-2009, 01:28 AM   #2 (permalink)
385 days old at PW
U just named ur problem, didn't define. How can v solve it in this way? Everybody would ask the same question, what's the problem exactly
__________________
I take my car out of garage hitting 9Gs. That's why I was not selected as a pilot because they do it in air going forward, I do it on ground going backwards |||||||| Ferrari's interior reminds me of local Railway Engine's interior ||||||| I would like to have a Rolla if they start producing it with company fitted BRAKES
panicslayer is offline   Reply With Quote
Old 01-07-2009, 01:41 AM   #3 (permalink)
677 days old at PW
Well, what i wanted to say was, while driving on cng car automatically (without I touching switch over button) switches to petrol and instantly switches back to cng. This thing has happened couple of times.
any ideas ?
Old 01-07-2009, 01:52 AM   #4 (permalink)
385 days old at PW
Hmmm may b a faulty switch or can b short wiring. Get it checked asap. Should not take more than 5 minutes to diagnose by a professional
__________________
Old 01-07-2009, 01:03 PM   #5 (permalink)
759 days old at PW
Connector or grip of CNG switch may be loose.
Fuse of CNG may be loose.
Or some other wire of CNG is not properly connected.
This is not "Automatic switching between cng and petrol" rather it is "Abnormal switching between cng and petrol"
__________________
!!Say NO to TOBACCO!!
Xplorer is offline   Reply With Quote
Old 01-07-2009, 02:09 PM   #6 (permalink)
235 days old at PW
dear this may be the problem of your touch switch which performs the operation of changing because very often swtich gets fault due to moisture or rust present in it. if its the fault of switch, the you can easily repair it just by cleaning it with spirit or thinner. otherwise check your fuse or grip etc.
Zyrak is offline   Reply With Quote
Old 01-07-2009, 02:23 PM   #7 (permalink)
1,362 days old at PW
does it happen at low rpm .... like when are slowing down on signals etc ? or at some steady rpm ?
auto switching happens in efi cars when rpm drops on cng to lowest level due to any problem, it converts to petrol, on gaining the rpm again, it switches back, had seen this prob in one frnds vario .....
explain the occurance of problem , scenario .....
__________________
-_____SmoOoOooKennnnn_____ !
stonedsaint is offline   Reply With Quote
Old 01-07-2009, 02:33 PM   #8 (permalink)
665 days old at PW
Sensor problem.....
change your switch..and save ur sensor of water
alimodell is offline   Reply With Quote
Old 01-07-2009, 03:29 PM   #9 (permalink)
1,541 days old at PW
ive got the same issue wid my dads Baleno, + sumtimes it doesnt even cumes to CNG and cumes wen it wishes, then sum times the abnormal switching btwn petrol nd CNG occurs
__________________
I am owner of a JDM vehicle.
chinyoti is offline   Reply With Quote
Old 01-07-2009, 10:41 PM   #10 (permalink)
283 days old at PW
Problem is with advancer get your advancer changed.
ahmedshaikhani is offline   Reply With Quote
Old 02-07-2009, 11:56 AM   #11 (permalink)
677 days old at PW
@stonedsaint,
yes you got it right. I think I have to adjust my cng for idling.
thanks,
@rest all
thanks for your suggestions and input.
Reply
Bookmarks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are Off
