Old 07-08-2009, 11:43 PM
bostupthecar
125 days old at PW
Default baleno master( free tips for baleno )
i have a lot of experience of using and maintaining baleno all types of balenos.its really a marvelous car of suzuki.but little diffferent to maintain from other cars.if u have some problems discuss with me on this forum.B-)
bostupthecar is offline   Reply With Quote
Old 05-11-2009, 11:15 AM   #381 (permalink)
212 days old at PW
thanks baleno bhai jee...mai ny ap sy request ki thi k mjy MAF and cam censer (2nd hand) ki price k bary mai koi estimate dy dain...ya agr new ki price ka pata hy to wo bata dain.....any one else other than baleno bhai jee agr aap mai sy ksi ko bhi pata hy tu bta dain...
__________________
Life is about 3 things...1-Plugs and Wires 2-Tight Air Filter Box 3-Advancer Of CNG Kit
waqas34 is offline   Reply With Quote
Old 05-11-2009, 01:47 PM   #382 (permalink)
206 days old at PW
waqas tumhara wo problem hal howa ya nai gari band ho jatanay wala? jab electric load engine par yahi tha na?
yasirsa is offline   Reply With Quote
Old 05-11-2009, 02:29 PM   #383 (permalink)
1,128 days old at PW
AoA BalenoMaster....
Quick question, I have Baleno 2005 Sports and when I am drving on rough road (bumps & holes), my car makes quite some noise as if driving a Mehran .. some say I need to check shocks and get those replaced? do you think it is possible thts shocks are damaged?
And how do I get rid of power steering belt/bearing noises? I changed both twice but the noise is still there, one thing I found out that the power steering fluid bottle doesn't have the filter inside which my mechanic told me to change since it might cause dirt to reach the bearing ...? can you please help
imrankamal is offline   Reply With Quote
Old 05-11-2009, 04:15 PM   #384 (permalink)
125 days old at PW
Quote:
Originally Posted by imrankamal
AoA BalenoMaster.... Quick question, I have Baleno 2005 Sports and when I am drving on rough road (bumps & holes), my car makes quite some noise as if driving a Mehran .. some say I need to check shocks and get those replaced? do you think it is possible thts shocks are damaged? And how do I get rid of power steering belt/bearing noises? I changed both twice but the noise is still there, one thing I found out that the power steering fluid bottle doesn't have the filter inside which my mechanic told me to change since it might cause dirt to reach the bearing ...? can you please help
baleno suspension voices are usually from rock ends of steering bush of chimtas.shocks ki awaz bohat kam hoti hay check it from some shock specialist repair ho jatay hain.but i think this voice is from rockends and chimtas.rockend repair na krana purchase new other wise steering hard ho jata hay.power steering ki pulleys check karen agar woh rotate kertay waqt hilti hain tu change them.other wise agar aap bearing aur belt change ker chukay hain then apply some grease to belt.yeh tamam problems bumpy roads ki wajha say hoti hay try to use good road avoid bumps.
Old 05-11-2009, 04:24 PM   #385 (permalink)
125 days old at PW
Quote:
maf and cam censor price varies from 3000-5000 saray censors iss price main atay hain each one not all.waisay censor bohat kam kharab hota hay iss main carbon aa jati hay clean and use a1 ho jaey ga.electrician check ker k bata sakta hay k yeh kharab hay k nahin.
Old 05-11-2009, 04:47 PM   #386 (permalink)
212 days old at PW
yaar yasir...wo problem hal kahan hona tha wo tu or bhi kharab ho gia hy...1st gear mai car ko pick daity waqat agr steering ghomao tu car band ho jati hy....mjy lgta hy ya sara problem weak engine ki wja sy hy...ab is problem k sath guzara kerna pary ga...jb engine over haul hoga tu sara car theek kerwao ga
__________________
Old 05-11-2009, 05:00 PM   #387 (permalink)
212 days old at PW
baleno bhai jee...electrician tu us din chutti pr tha...mechanic ny problem sort out kia tha or according tu him censer tu change hi ho sekta hy clean ya repair nhn...if you are sure that MAF censer can be serviced and repaired,kindly inform me so that i can save that much amount of expenses
__________________
Old 05-11-2009, 10:44 PM   #388 (permalink)
206 days old at PW
wasay ya problem weak engine ka nahi am damn sure zara shahid ka thread parhoo us ko bhi tumhari tarha ka problem hay may is ka camshaft sensor maf sensor mushkil hay is may problem ho camshaft sensor our crankshaft sensor ya do problem check karoaoo
Old 05-11-2009, 10:46 PM   #389 (permalink)
206 days old at PW
check karoo crank case leak to nahi hay nichay say check karna zaroor simple is that k tumhara ecu mangae nahi kar pa raha sensors k zariyaa k is par kitna load hay tum break lights on karoo ya jo bhi load tumhari gari load nahi handle kar sakti so check camshaft sensor and crankshaft sensor
Old 05-11-2009, 11:25 PM   #390 (permalink)
125 days old at PW
waqas bro aik do mechanics ko check kerwa lain agar woh kehtay hain k censors are faulty then change them kiun k weak engine ki wajah say rpm drop nahin hota.aap pindi say ho kya?
Old 06-11-2009, 08:13 AM   #391 (permalink)
37 days old at PW
Dear Baleno Master, i have reviewed all your suggested solutions and it appeared very helpful to get rid of most of common problems. Now a days i am facing missing problem in 1st ad 2nd gear while driving on petrol and car gains top speed only 110Km at its most in 5th gear/3500rpm which is quite not acceptable. My mechanic advised to change the fuel pump, do you see any other option to solve this problem. In case i decide to change the fuel pump, what should be its cost?
asgharshoaib is offline   Reply With Quote
Old 06-11-2009, 12:13 PM   #392 (permalink)
212 days old at PW
boooooooom.....petrol pr missing ka problem khatam...absolutely khatam...half self start in morning...fit like a horse...and you know what???I EVEN DON'T KNOW HOW THIS HAPPENED...just like the problem started all of sudden, it resolve all of sudden...pata nhn ka problem tha...hahahah....or ab ak or problem hogia hy...car low speed pr patakha maar rahi hy...-P...or ab phr kch pata nhn k asa ku hy...air filter box jitna tight ho sekta tha utna tight kr dia pr koi faida na hoa
__________________
Old 06-11-2009, 12:39 PM   #393 (permalink)
[/quote]
AoA BMaster ... thank u for ur wise advices .. I am relatively new in ISB and I would apprecaite if you can guide me any shocks specilist as well a experienced mech for power steering issue please...
Old 06-11-2009, 12:49 PM   #394 (permalink)
1,514 days old at PW
i agree with baleno master on the issue of back fire best solution is to avoid getting your car engine washed and if any one is stll havinga problem the get the throttle body changed you can get that for Rs. 1500 and you can get the kabli coils for Rs. 3000 only
khanjee79 is offline   Reply With Quote
Old 06-11-2009, 12:56 PM   #395 (permalink)
dear imran kamal there is a shock specilist in rawalpindi go to babu mohallah there is a guy name DORA SHOCKS WALA he is a bit expensive but he gives a warranty of 6 months. As for a experienced mech for power steering issue please come to Golra More and there is a CNG Station by the name of Mugal Super Save adjustant to that station there is a workshop by the name of Pakistan Automobile contact Mr Shahid. He used to be the head foreman in suzuki motors
Old 06-11-2009, 05:54 PM   #396 (permalink)
212 days old at PW
Quote:
khan jee car ki throttle body bilkul theek hy,car engine bhi wash nhn hoa...and kindly agr aap mjy 2500-3000 ki kabli wires dilwa sekty han tu zaroor btaee...i shall need your help...thanks in advance
__________________
Old 07-11-2009, 03:31 PM   #397 (permalink)
125 days old at PW
AGAR TU CAR GAS PER MISSING KERTI HAY TU FUEL PUMP CHANGE NAHIN HO GA AUR AGAR PETROL PER KERTI HAY THEN THERE IS A PROBLEM OF FUEL PUMP.JAB BHI CAR MISSING KARAY SAB SAY PEHLAY PLUGS SAAF KAREN YA CHANGE KAREN.
Old 07-11-2009, 03:37 PM   #398 (permalink)
125 days old at PW
FOR ALL SUSPENSION WORKS I PREFER GAWALMANDI IN PINDI THERE IS A SHOP NEXT TO KIANI AUTOS I FORGOT ITS NAME YOU CAN SEE IT URSELF ITS THE BIGGEST SHOP OF SUSPENSION IN TWIN CITIES.WAHAN HER KISAM KA SUSPENSION KA KAM KYA JATA HAY.LAIKEN BILL BOHAT BARA BANATAY HAIN PER AM BHI VIP KERTAY HAIN.
Old 09-11-2009, 02:12 PM   #399 (permalink)
209 days old at PW
Hi Baleno Master.Sir main Ye Coils say tang aa cuka tha Kabli b juldi kharb ho gayee denso ki.Mujay ek Macanic ne Kaha ka tum 1.6 ka jo system hai coils ka wo lagawoo.so main ne Asa he Kiya and MashaALLAH Gari ki pick b bohat ber gaye hai and Kebi Backfire nahi kiya.Ap k khayal se ya teek hai 1.3 main 1.6?
__________________
usman
usman9294 is offline   Reply With Quote
Old 09-11-2009, 02:49 PM   #400 (permalink)
Suzuki Authorized dealer in ISB took 3000Rs. from me for throttle body cleanup
Reply
Bookmarks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are Off
