Old 27-08-2009, 10:49 AM   #1
shahsahab
1,087 days old at PW
Default OIL CHANGED OF XLI 2009
Dear Pakwheelers freinds
i want to know that on how many kilometers ,OIL should be change of COROLLA XLI 2009 ,my father have gone 2 times at defence motors they are saying that when car done 5000 than the oil will be changed
i am confused
is that right
__________________
-SHAH SAHAB
shahsahab is offline   Reply With Quote
Old 27-08-2009, 11:00 AM   #2 (permalink)
1,192 days old at PW
if u r using good oil max is 3500 but i change mine at 3000
__________________
!!!!!!!Say No to Suzuki!!!!!!
faheemboy is offline   Reply With Quote
Old 27-08-2009, 11:07 AM   #3 (permalink)
Dear Brother
i am asking the first OIl change , the first one my car is brand new
__________________
-SHAH SAHAB
Old 27-08-2009, 11:09 AM   #4 (permalink)
1,865 days old at PW
if you are planning to undergo maintainance from Toyota, do as they say or you'll confuse everything. Toyota's petrol oil timing IS 5000km. other brands' depends on their claims for example Shell fellows say blue box - 10000 km, yellow - 5000 km, red - 3000km and so is the case with other companies. i use Caltex Havline but change at 3000km because of an old engine.
VAJIH102 is offline   Reply With Quote
Old 27-08-2009, 11:20 AM   #5 (permalink)
hmmmmmm
thanks brother
well my car is still on petrol , i am not going to maintain my car from toyota but bc of the first service i was thinking that first service should be from toyota
otherwise my mechanic is have good information about toyota
__________________
-SHAH SAHAB
Old 27-08-2009, 11:25 AM   #6 (permalink)
1,016 days old at PW
my corolla goes to authorized dealer and oil is changed at 4000km
__________________
S65 AMG V12 Cylinder kW 450 (HP 612) 5-speed automatic with speedtronic cruise control Diamond white metallic 20" AMG alloy wheels Exclusive PASSION leather - cashmere beige Designo black nappa leather roof lining Carbon fibre trim Panoramic glass sunroof - electric Night view assist plus
£165,489
qwertypoiu is offline   Reply With Quote
Old 27-08-2009, 11:28 AM   #7 (permalink)
708 days old at PW
Shah jee, in order to keep the car living long you should change the oil and the filter at around 4000 kms depending on the condition of oil, driving style load etc etc. Once you have clocked 4000 on the oil, check the dip stick for, color of the oil (should not be black) and its viscosity, it should feel like butter on your finger tips.
Stick to one brand of oil.
__________________
Real jeeps have horizontal grills.
sarmadqureshi is online now   Reply With Quote
Old 27-08-2009, 11:45 AM   #8 (permalink)
at 1000 the running gets complete then u have to change it.
its ur own car order them to change it
__________________
Old 27-08-2009, 11:50 AM   #9 (permalink)
1,261 days old at PW
First oil should be changed at 1000km as faheem boy has mentioned.
and then it should be changed on 3000 or 5000 max..
farhannk is offline   Reply With Quote
Old 27-08-2009, 11:59 AM   #10 (permalink)
1,182 days old at PW
toyota doesnt need oilchange after 1000 like suzukis.
__________________
How to Modify Your car: Put some fiberglass crappy looking bumpers, spoilers are essential for your daily driver, and don't forget the TypeR.
saadisb is offline   Reply With Quote
Old 27-08-2009, 12:00 PM   #11 (permalink)
1,142 days old at PW
after 5000 kms
Farhansa is offline   Reply With Quote
Old 27-08-2009, 12:57 PM   #12 (permalink)
thanks to all brothers
it means it is truth to go before 5000
thanks to all
__________________
-SHAH SAHAB
Old 27-08-2009, 01:27 PM   #13 (permalink)
1,307 days old at PW
^ you can change your oil before 5k km for your own satisfaction but only a phd in lubrication can exactly tell you whether u need to change oil before 5k km or not. the ones who say that you shud say that engines wear a lot in the initial 5k km. but is it true for all the cars when different manufacturers use differet levels of surface finish and tolerances in the machining for the moving parts in an engine. n also the engines get tested at the manufacturing sites and their different parameters are monitored before cars are sent to the market. n the material that gets wear off from the moving components have to wear out anyway over the lifetime of the engine. then why isnt it better to change the oil after 5k km and let the parts of the engines get machined quickly to the desired level. the material thats gets wear off and suspends in the oil doesnt change its lubricating properties a lot - there are other factors that make the oil unusable such as the oxidation of the oil. etc etc. and oil contaminants, if larger than some limit get filtered out by the oil filter. n oil filters are designed in such a way that they last longer than it takes for the oil to become unusable. so folks there are tolerances and safe limits in every engineered product. you can use the products wid the peace of mind within the limits specified by the manufacturers. if you cannot visualize all these things then your common sense would tell you only the basics - that the engine wears off initially and u shud change the oil.
so i recommend that you shud inspect the oil after 3500 km or so. if there isnt any major change in the thinckness and colour then change it after 5k km.
__________________
Retaliator is offline   Reply With Quote
Old 27-08-2009, 01:29 PM   #14 (permalink)
use SL or higher grade oil for your vehicle n dont use PSO's oils.
__________________
Old 27-08-2009, 03:36 PM   #15 (permalink)
1,886 days old at PW
For Corolla, the first 1,000 check up free. They will do a general check up and will not change the oil. When I took my car for first 1,000 they said no need to change oil as it was good for 5,000K. As far as the wear and tear is concerned, for what the filter is? Any tiny metal piece coming out of break-in would be collected by the oil filter.
__________________
When arguing with a stupid person, make sure he is not doing the same.
autophile is offline   Reply With Quote
Old 28-08-2009, 07:10 PM   #16 (permalink)
1,598 days old at PW
if not frm Toyota & first check up by Toyota has been done,
then change the oil &stick to some good brand like MOBIL1.
there r various oils, some need to be changed @ 2000km & good synthetics last upto 12,000km.
its upto u.
__________________
1.8 VVt-i
ch_jut is offline   Reply With Quote
Old 28-08-2009, 08:24 PM   #17 (permalink)
Autophile, i remember when nanaji's Cultus came brand new in 2002 and we went for the 'First Free Inspection' they changed a bolt from the bottom of the car and oil of the gear. loads of sludge had gathered there.
Old 28-08-2009, 08:55 PM   #18 (permalink)
1,100 days old at PW
shahsahab
i think u r not satisfied. the 1000 km oil change is very gud for ur new car. as one of da members said that they took heir cultus for first free inspection and the oil was changed(both transmission and engine oil) there was a lot or sludge material cuming out...
so according 2 the routine maintanence, the oil is changed after every 5000 km as suggested by toyota motor corporation japan. i m a toyota technician in TOYOTA SOUTHERN MOTORS. and I hav also worked in suzuki dealership i-e CARACHI MOTORS.
u just do one thing that if u dont want to get ur car maintained from the dealership, then go to dealership and purchase the TM0 2000 TOYOTA GENIUNE MOTOR OIL and the Geniune oil filer. then u can get the oil changed from anywhere.....
always remember that the geniune parts are always safe for a long hassle free drive.....
Regards
Danish
03333738698
civic_90 is offline   Reply With Quote
Old 28-08-2009, 09:09 PM   #19 (permalink)
361 days old at PW
sir 3000km
__________________
"B2 Innovations - Events & Media Managers"
http://www.facebook.com/group.php?gid=129332754507
adeelshah is offline   Reply With Quote
Old 28-08-2009, 09:11 PM   #20 (permalink)
1,489 days old at PW
sir sab asa hi hain
change oil after 5000km which u get from toyota dealers...
m doing the same from last 2 years ..my car done almost 30k now
__________________
Scuderia Ferrari F1
rozzzzz is online now   Reply With Quote
Reply
Bookmarks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are Off
