Old 25-10-2009, 12:47 AM   #1
ali_7890
318 days old at PW
Default Engine Oil?
Havoline or Toyota Genuine Motor Oil.
Does it make any difference?
which one's better?
And what are those special oil for CNG?
ali_7890 is offline   Reply With Quote
Old 25-10-2009, 01:30 AM   #2 (permalink)
385 days old at PW
IMHO, oil really doesn't make any difference unless you don't put this type of oils
http://www.pakwheels.com/forumreply_az_TopicID!111547~ForumID!21~pw.html
__________________
I take my car out of garage hitting 9Gs. That's why I was not selected as a pilot because they do it in air going forward, I do it on ground going backwards |||||||| Ferrari's interior reminds me of local Railway Engine's interior ||||||| I would like to have a Rolla if they start producing it with company fitted BRAKES
panicslayer is offline   Reply With Quote
Old 25-10-2009, 02:39 AM   #3 (permalink)
1,638 days old at PW
Try synthetic oil like entry level ZIC A+ or a bit expansive ZIX XQ or u can afford Mobil 1.
Read about the benefits of synthetic oils and you will use it yourself. or give me your email ID i will send you a very informative book on Engine oils.
ansarghani is offline   Reply With Quote
Old 25-10-2009, 04:10 AM   #4 (permalink)
318 days old at PW
whats the difference b/w synthetic oil and the normal oil?
And from where can I get Mobil1? I havnt seen any yet
Old 26-10-2009, 03:08 AM   #5 (permalink)
Synthetic oil is a chemical lubricant specially developed to meet the lubrication requirements of an engine.
A very good example: It is like using hammer (synthetic oil) to nail a nail rather then a brick (Natural oil), the brick will break apart during the accomplishment of the task. You know natural oil start chemically decomposing on its use, while synthetic oil developed to bear the chemical decomposition.
You know the drain interval for natural oil is (3000km) while for synthetic oil it can be up to 15000km (depend on the oil and dirt conditions)
Do not get deceived with Synthetic formula and fully synthetic. Go for fully synthetic oil. i think Best available oil is Mobil1, you can find it in a good shop dealing in motor oils.
Regards
Old 26-10-2009, 03:14 AM   #6 (permalink)
http://www.zag.si/~jank/public/bmw/oil_bible.pdf
Read this book....
Old 26-10-2009, 07:22 PM   #7 (permalink)
318 days old at PW
Thanks man! nice info.
One more thing. Can you tell me exactly where to find the Mobil1 oil?
And, is TOYOTA GENUINE MOTOR OIL synthetic too?
Is it a good idea to purchase it from their showroom?
Old 26-10-2009, 07:27 PM   #8 (permalink)
981 days old at PW
@ali
TGMO is not synthetic. If that is what you want, Toyota Oil, then its safest to purchase from a 2S or 3S dealer. But be careful about specs, if its 20W-50, know that its meant if the car will be driven while the temp is 20 C to 50 C (acceptable for KHI, but Id recommend 10W-40).
__________________
What good is a Genius without the Human aspect?
HumanGenius is offline   Reply With Quote
Old 26-10-2009, 09:34 PM   #9 (permalink)
631 days old at PW
And what about Liquy Moly ( Germany)Engine and gear oil? Is it synthetic and good for Pakistani Conditions?
Burki is offline   Reply With Quote
Old 27-10-2009, 12:39 AM   #10 (permalink)
631 days old at PW
Anyone have any experience or knowledge about liquy Moly engine and gear oil?
Old 27-10-2009, 02:34 AM   #11 (permalink)
@Burki
Liqui Moly is good renowned company since 1957.
I do not exactly now if synthetic oil available in Liqui Moly, you can ask the dealer. if it is synthetic then it must be mentioned on the bottle/container.
Conditions in Pakistan is generally dusty, always try to use genuine or the best quality of Air filter available. Air is the only source of dust or contamination in the engine, which eventually contribute in the wear and tear of the engine.
Old 27-10-2009, 10:32 PM   #12 (permalink)
318 days old at PW
One more thing.
Synthetic oil for CNG is different or the same?
Old 28-10-2009, 01:00 AM   #13 (permalink)
@Ali
Haven't heard about CNG synthetic. i don't think so there is such a difference in CNG and non-CNG oils, it seems a marketing scheme to me...
Which car do you have? and currently which engine oil you are using?
Old 28-10-2009, 04:00 AM   #14 (permalink)
318 days old at PW
I have a Coure 04.
And I use Shell Helix.
Old 30-10-2009, 01:55 AM   #15 (permalink)
Ok..mileage on the clock? if you have driven considerable number of miles of your car on Natural lubricant then conversion to synthetic oil MAY BE not very much recommended. i have sent you the book, do read about it in detail.
My bro have Santro, he switched to synthetic after some 60000KM, working fine.
Old 30-10-2009, 10:43 PM   #16 (permalink)
318 days old at PW
Just crossed 54,000 KM last week.
I've driven 3500+ KM since my last oil change.
Old 30-10-2009, 11:26 PM   #17 (permalink)
@Ali
i am sure you can use synthetic oil for your car.
just make sure keep your AIR FILTER clean! VERY IMPORTANT!!
Old 30-10-2009, 11:57 PM   #18 (permalink)
318 days old at PW
O its clean alright. Got it from Toyota for 800RUPEES!!!!! :|
Old 31-10-2009, 07:23 AM   #19 (permalink)
28 days old at PW
All oils are same, its just the brands have different names. Look for API (American Petroleum Institute) grade SL or SM, these are the latest oils and use 20-50W since we live in hot weather. These are the standards which are written on all oils, this SL and SM are made for newer engines. If u want more info read all this on this site
http://www.carbibles.com/engineoil_bible.html
usman3206 is offline   Reply With Quote
Old 31-10-2009, 07:34 AM   #20 (permalink)
31 days old at PW
Dear Ali,
Just forget what anybody tells u . If you need a good performance oil not just the brand name then contact me on gtlube_1@hotmail.com. Ill not just give you a proper oil according to your ca but also you gonna save money.
Regards,
Omer
Quote:
Originally Posted by ali_7890
I have a Coure 04. And I use Shell Helix.
Slip99 is offline   Reply With Quote
Reply
Bookmarks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are Off
