#1 |
Can anyone tell me the exact engine type and specifications of HONDA CIVIC 2000 Vti?
__________________
I cried because I had no TURBO, until I met a person who had no VTEC |
#7 (permalink) |
I too think its D16y8. Here is the info source wiki.
li value=0"Displacemnt : 1590cc /li li value=0"Bore and Stroke : 75 mm × 90 mm (3.0 in × 3.5 in) /li li value=0"Rod Length : 137 MM /li li value=0"Rod/Stroke : 1.52 /li li value=0"Compression : 9.6:1 /li li value=0"Valvetrain : SOHC VTEC 4 valves per cylinder /li li value=0"Power : 127 hp (94.7 kW, 129 ps) 6600 @ rpm /li li value=0"Torque : 111 ft·lbf (45.79 kg/m, 145.1 Nm) 5500@ rpm /li li value=0"Head Code : P2J /li li value=0"VTEC Switchover : 5500 rpm /li li value=0"Piston Code : P2P /li li value=0"Redline 6900 rpm /li li value=0"Rev Limited To 7200 rpm /li li value=0"ECU Code : P2P /li
__________________
Power of D15B 3 Stage Vtec |
#20 (permalink) | |
Quote:
you are funny toooooooooooooooooooooooooooo so what you are saying 1.8 can give tough time to 3.0 and 1.6 cant to 1.8????? see the difference between two? i dont think any stock 1.8 can stay close to 3.0 and also know you would claim that it is stock |
| Bookmarks |
| Thread Tools | Search this Thread |
