Old 06-11-2009, 06:56 PM
aamir_shhbz
959 days old at PW
Default Is there any expiry date for Air bags
Guys,
I want to knw that is there any expiry date for air bags if yes then how to replace it.
How much it cost.
Thnx
aamir_shhbz is offline   Reply With Quote
Old 06-11-2009, 09:33 PM   #21 (permalink)
811 days old at PW
Quote:
Originally Posted by aamir_shhbz
http://en.wikipedia.org/wiki/Airbag
I didn't know Wiki was an automaker.
Let's see what it says at the very top of this article:
Do I really have to explain!
__________________
My opinions, suggestions and thoughts are strictly my own. I reserve the right to be human and make mistakes.
riz_ is online now   Reply With Quote
Old 06-11-2009, 09:37 PM   #22 (permalink)
267 days old at PW
No but they require checking/maintenance after every 6-8 years.
__________________
spending money tht i dont have, to buy thingz that i dnt need, to impress ppl tht i dnt knw!!
iLLDuDe786 is offline   Reply With Quote
Old 06-11-2009, 09:45 PM   #23 (permalink)
1,678 days old at PW
Quote:
Yeah you're right. I'm not an automaker.
__________________
"Corvettes seduce me more than girls do..."
wik_a is offline   Reply With Quote
Old 06-11-2009, 09:46 PM   #24 (permalink)
Quote:
Originally Posted by wik_a
WOW... I should open "Advanced Airbag Replacement" facility ASAP lol.
If you do, hire Toofan as your parts installer. He will swipe a few additional parts as expired, for latter sale, of course.
[/quote]
LOL...
__________________
Old 07-11-2009, 12:31 AM   #25 (permalink)
981 days old at PW
@ Riz, wik, Toofan, interesting conversation (Y)
@wik
Yaar make sure you open an outlet in Islamabad so I can check my cars too...
__________________
What good is a Genius without the Human aspect?
HumanGenius is offline   Reply With Quote
Old 07-11-2009, 12:55 AM   #26 (permalink)
1,898 days old at PW
No there is no expiration date.
__________________
driver slower than you is an idiot and anyone driving faster than you is a maniac
toofast is online now   Reply With Quote
Old 07-11-2009, 01:15 AM   #27 (permalink)
1,660 days old at PW
Quote:
Originally Posted by HumanGenius
I dont know but it sure sounds logical. Airbags sitting compressed for years with heat and cold, high and low pressures, I think they should at least be inspected every couple years. And those who are saying there is no expiration date, know that practically everything has an exipry date - sooner or later. Unless your banking on the fact that by the time an airbag system gets messed up, either its been deployed or the cars a clunker
bro airbags do not sit "compressed", they have chemicals inside that react instantaneously upon an impact to release gases that inflate the airbag. it all happens in a split seond, ofcourse, as we all know.
here's a source if you don't believe me:
http://en.wikipedia.org/wiki/Airbag :
h4
Inflation
/h4
When the frontal airbags are to deploy, a signal is sent to the inflator unit within the airbag control unit. An igniter starts a rapid chemical reaction generating primarily nitrogen gas (Nsub2/sub) to fill the airbag making it deploy through the module cover. Some airbag technologies use compressed nitrogen or argon gas with a pyrotechnic operated valve ("hybrid gas generator"), while other technologies use various energeticpropellants. Propellants containing the highly toxic sodium azide (NaNsub3/sub) were common in early inflator designs. However, propellants containing sodium azide were widely phased out during the 1990s in pursuit of more efficient, less expensive and less toxic alternatives.sup[citation needed]/sup
The azide-containing pyrotechnic gas generators contain a substantial amount of the propellant. The driver-side airbag would contain a canister containing about 50 grams of sodium azide. The passenger side container holds about 200 grams of sodium azide.sup
26
/sup The incomplete combustion of the charge due to rapid cooling leads to production of carbon monoxide (CO) and nitrogen(II) oxide as reaction by-products.sup
27
/sup
The alternative propellants may incorporate, for example, a combination of nitroguanidine, phase-stabilized ammonium nitrate (NHsub4/subNOsub3/sub) or other nonmetallic oxidizer, and a nitrogen-rich fuel different than azide (eg.tetrazoles, triazoles, and their salts). The burn rate modifiers in the mixture may be an alkaline metal nitrate (NOsub3/sub-) or nitrite (NOsub2/sub-), dicyanamide or its salts, sodium borohydride (NaBHsub4/sub), etc. The coolants and slagformers may be eg. clay, silica, alumina, glass, etc.sup
28
/sup Other alternatives are eg. nitrocellulose based propellants (which have high gas yield but bad storage stability, and their oxygen balance requires secondary oxidation of the reaction products to avoid buildup of carbon monoxide), or high-oxygen nitrogen-free organic compounds with inorganic oxidizers (e.g., di or tricarboxylic acids with chlorates (ClOsub3/sub-) or perchlorates(HClOsub4/sub) and eventually metallic oxides; the nitrogen-free formulation avoids formation of toxic nitrogen oxides).
From the onset of the crash, the entire deployment and inflation process is about 0.04 seconds — faster than the blink of an eye (about 0.2 seconds). Because vehicles change speed so quickly in a crash, airbags must inflate rapidly to reduce the risk of the occupant hitting the vehicle's interior.
__________________
I solemnly swear that i am up to no good!
kool is offline   Reply With Quote
Old 07-11-2009, 01:47 AM   #28 (permalink)
1,572 days old at PW
on my car (alfa romeo, its says 10yrs....(read it somewhere.. prolly on the side pillar).. .. will get the pic tomorrow..
__________________
we'll miss u...
ahsen_rg is offline   Reply With Quote
Old 07-11-2009, 12:52 PM   #29 (permalink)
309 days old at PW
to check whether the are expired or not ...bang ur head on steering wheel if it inflates then its ok u can use it again :p
if not then u surely have to change :p
waisay i have tried banging ma head on alto but i think they didnt provide one :p
BHAI NO NEED TO CHECK THE VALIDITY
__________________
KARACHI RULES, KARACHI ROCK, KARACHI SLAM, KARACHI LIVE, KARACHI DREAMS, KARACHI SOUL, KARACHI HEART, KARACHI SUPPORTS. KARACHI IS PAKISTAN....
xalmanreyaz is offline   Reply With Quote
Old 07-11-2009, 07:46 PM   #30 (permalink)
959 days old at PW
What i understand from all this discussion is some automaker do recommend the replacement of airbags after ten years but it is not practical to do. It may be cost you more than vehicle value and also there is no such facility in Pakistan. So we should ignore the expiry date issue.
Old 07-11-2009, 07:50 PM   #31 (permalink)
959 days old at PW
What i understand from all this discussion is some automaker do recommend the replacement of airbags after ten years but it is not practical to do. It may cost you more than vehicle value and also there is no such facility in Pakistan. So we should ignore the expiry date issue.
Old 07-11-2009, 07:51 PM   #32 (permalink)
981 days old at PW
@kool
Interesting (Y)
__________________
Reply
Bookmarks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are Off
