Where is the engine number located on the engine block of Daihatsu Mira L250? I am attaching picture as a reference. Please help!
Bump....
EF-SE inline 3
Its EF-VD...
I need the engine number not the model dude...!
you have provided us some good information with us
At last I got the engine number its on the side of the engine block and quite difficult to see through naked eye, one needs a mirror for it !
I need to find engine number of Mira L275S...please help..where it is written ?
look for it at left side of engine. at your right side when facing engine from front. for daihatsu engines it is often under distributor.
there are two numbers (in two lines) on a sticker on the tapet cover on the location you mentioned.,, but nothing mentioned that its an engine number..any idea how an engine num for mira starts?
engine no for my normal mira 2006 was on the right side of the engine, it could only be read with great difficulty with a mirror. But this engine is DOHC....
So where should be engine num of L275S - 2007
engine no is also on a small metal plate called tickli by mechanics and your reg. book also. chances are slim that it is on that sticker. once you know its format you can find for similar one on your engine.
a mirror and torch will be helpful for sure.
locate it over right side under the distributor & close to water intake line while looking from front the engine block curve mating with transmission bell housing. True its bit tricky to read
Found it.....just a bit right to the exhaust and behind bumper gril.. written vertical and starts with A and at the last a big KF. Is that correct? is that realy engine number?
use cam phone or digital cam to snap a pic & post please
Yaar can some one share the "image" of Engine Number of any daihatsu car Move Mira etc.
I also need this
I need the location of engine no. in 2007 mira L250
