My car shows 28k mileage which i know Japanese cars meters are always tempered here but even 70-80k km should not be an issue in Japan as its 4-grade and says +15% and below that it says 50%.
I have to change these:
1.Air filter (I bought Leppon for Rs550, any good or should i change it with some other? Has to be under Rs1k.
It doesnt have a cabin filter or any space for it, i took the glove box out and saw, does it harm the cooling coil or any other AC part?
2.Oil (Is ZIC A+ better or ZIC OW considering temperatures upto 45degrees C here and then AC? Dont want to spend over 2k)
3.Oil filter (VIC any good? Costs Rs360. If any other, has to be under Rs500, i change it on every oil change at 6k kms)
4.Spark plugs (Do normal NGK around Rs130 each ones do the job, i can stretch upto Bosch ones tht come in a packet of 4 and cost around Rs1300 i guess they are made in Germany, or any other in that range under Rs1500 for all 4?
5.Radiator coolant (Caltex or ZIC? Toyota 4L can is very expensive!)
6.Gear Oil (Shall i change it? ZIC? or any other?)
Im not sure if i should be changing 4,5 and 6. How to check if there is need?
*And i saw STP injector cleaner and STP octane booster at a store. Do they really work?
I was thinking of using one or both of them on the next full petrol refill. Though not sure if the Injector cleaner is put in the fuel tank LOL.
Thanks in advance if some of u take out time and guide me :)
