Congrats.engine nymber is written on the block on right side. left side of the radiator, The Security System Japanese provide is actually Immobilizer. If your car has a remote key then it definately has onehere is how u can check if its in order.get inside the car and lock it through the remote. wait inside for a minute and open the lock through the door handle, if the horn starts honking it means that it is in order. Now to stop the horn from honking just insert the key in ignition and start the car
Not honking. But when I lock car I can see inside one red light blinks. I did as you directed but not worked for me
Just checked its working.Now I found double indicator button not working. Seems fuse is out. Do you have idea.I want to tell that I have switched from Honda city 2008 to this car. City was bought zero meter. I must say this car is more comfortable than city. Maybe pick is not high like city but very impressive car.
Check the grip , waise gari nahu dekhi thi lene se pehle ?
Bro. My cousin bought for me from his uncle. They told me one left door is touch up rest is clear. For double indicators they are working in case of unlocking or locking but not working with button specially for it. Can you guide me where this grip is ?
Pls also suggest should I use 14" or 13" rims
For indicator, open up the area where the button is located, and remove the grip and plug again, problem will be solved.
I dont have correct tools so I guess I should take it to mechanic.
Dont change rims. it will mess fuel economy but if u really wanna go for it, then get 13"
Infact I notice rims are 14" (not alloy) . My father was suggesting me for packing as in Faisalabad speed breakers are killer. But I notice my car clearance is good due to these so I think 14" can be OK as well. As I get 20 to 24 km/l
You don't need tools, just open up one or two screws and pull,
I think if I go for 13" I can get more good millage. But I think G package also have originally 14" rims
Ok Tommrow I will try
Do you means buttons are near by double indicator button
Did the horn honk immediately or it took some time?
Sent from my HUAWEI P6-U06 using PW Forums mobile app
it takes a few seconds
Where are screws to fix the grip for this button
Try to gently pull this cover, it feels as if it is not fixed with screws, and if u r unable to do it, take it to any car accessories shop or one who works on cd player and tell him to check the grip of the Double Indicator button,
A strange thing I notice. Its seems it was 4wd and crank is remove to make it 2wd. Do you agree. ?
Tks for help.double indicator fix with gripper. One strange thing eco idle worked for once but it disappear after one time. Is it normal.or what criteria it need to work again.
