AoA, Brother, i wanted to put the request to share the Mira e:S manual in english?
AoA, I wanted to get the experts advice as i have been adviced by the famous mechanic Javed on GT road to put in ZIC A(10-40) not ZIC A+ (5-20)........i am confused now which one should be oke for the ride.....mine is Mira e:S 26000KM....Mechanic claimed that you never know if the meter is tempered and the environment is not as same as japan......Help please?????
Hi can you please email user manual of Daihatsu Move 2008 model. my email is madakamoyo2014@gmail.com will be thankful.
My mira e.s in now 50,000 driven I want too chnge its transmission oil how many liters it require and which company oil should I use and I also want too replace its tyres which company and size best too reduce road noise.Please kindly suggest
Be careful with this bro, this manual image i believe is for L275 mira (2007 onwards model). Mira ES should probably have some newer engine / transmission ? correct me if i am wrong please.
Yes, it is of old Mira. But all information is same as of Mira es. I have cross checked
Sent from my H30-U10 using Tapatalk
Daihatsu Move 660cc model 2013.Any body can tell me what is the best time after how many KM can be change oil? I'm using Zic mobil oil
Salam to all men abhi mira 2010 bye ki jin bhai se li unhon ne muje hevoline ka 5w 30 oil dalne ko kaha tha me ne wohi dala lekin 1500km chalne ke bad oil thora sa kum ho gaya he kia men koi or grade use karonplz help
read the complete add, but most of the people instead of suggesting the exact thing came here to open their own forum........................that really really sucks..................no one exactly suggest the owner about exact grade of engine oil.
5W-30 is less viscosity its better go to 5W-40 just bit higher and better then 5W-30 for summer.
You should try Atlantic Brand its imported and 100% genuine. go to this link and check prices latest atlanticoilstore.com
Looks like ur car engine rings have gone weak. Get that checked first.
Doesnât matter which ever oil u use. It should be changed at your 4000km max. Due to our dirty environment and heat oils loses its viscosity and if u use that oil it reduces engine life.
That is absolutely correct, one should use 5W-40 in summers and 5W-30 in winters. These cars are designed for Japan where the weather is much colder as compared to the weather here in Pakistan especially considering the AC keeps working for long durations. Always go for 5W-40 in summers and 5W-30 during the winters. I prefer shell Havoline 5W30.
