gr8 project man,,, good job and well done u really put a lot of effort to it,,
by the looks of pics a few things needs attention (again wt the pics show so plz dont mind if iam wrong)
1st: the intake filter in the body looks good but can it prevent water vapors from getting to engine??? like the filter box or the u shape bend in the intake pipe of the usual intakes prevent the water vapors from getting to engine
2nd: the radiator pipes seems to lack a bit ground clearance u know how roads r in pak ......
3rd: bro that power window switch housing really needs to change its location,,, id suggest u to make a custom metal plate for it as the switch in that housing can come out easily and u can cut the same size holes in th metal plate and install it some where on the right side of wheel under the meters,,,,
