ok .. open up the door handle with the help of screwdriver ..
remove the clip of the lever of galss opener .. with the help of small srewdriver/watchmaker ..
after removing all this .. remove the black pasltic its located where the back viewing mirror installed .. pull it its on clips ..
then slowly remove the clips by pulling the panel (clips on the edges of the panel) ..
after removing the clips .. try to slips the panel to upwards
