Community Forum Actions
Page 1 of 3 123 LastLast
Results 1 to 20 of 44
Like Tree37Likes
Thread: DIY: Honda City 04-08 Instrument Cluster Opening and Cleaning
    RollOnBigMaMa's Avatar
    Oct 2011
    3,870
    48 Post(s)
    19 Thread(s)
    Arrow DIY: Honda City 04-08 Instrument Cluster Opening and Cleaning
    Aoa dear fellow pakwheelers. Hope you people are fine.
    Well, this is my first DIY I have posted over here.
    The topic was discussed a lot in our Honda City Fan Club as "how to open the speedo of this city."
    A fellow member, A_N_memon @ PW posted some pics in the fan club as how to open it so i tried doing it on my city as well. Mine is 2004 model.
    My cluster needed cleaning and the three silver rings were very dirty. The space around the rings is a bit tricky and is not easy to clean. So, truck loads of dirt may be accumulated around them.
    First, its about how to open the cluster:
    The silver rings are fastened over the speedo by 4 clips which are stuck very hard. One needs a good force to remove them. But once u learn how to do it, its simple.
    Just put ur fingers n the rings as shown in the picture, and Exert an equal, balanced force. keep ur hands under control as no one would want to break the rings...
    The clips will come off with a click. Now u can remove the lower part easily.But remember to lower the steering column to its lowest cz only then will the rings come out.
    make sure that the trip meter reset key is not damaged while pulling the rings off.
    DIY Honda City 04-08 Instrument Cluster Opening and Cleaning -368789
    DIY Honda City 04-08 Instrument Cluster Opening and Cleaning -368790
    After I removed those rings, I washed them, sanded them a bit so that the surface becomes even and gave the them a repaint in silver colour.
    yes the genuine colour is different but I've already repainted all of my panels with the same colour, therefore, they'll match with them.
    Below are the Pictures:
    DIY Honda City 04-08 Instrument Cluster Opening and Cleaning -368803
    DIY Honda City 04-08 Instrument Cluster Opening and Cleaning -368805
    DIY Honda City 04-08 Instrument Cluster Opening and Cleaning -368806
    DIY Honda City 04-08 Instrument Cluster Opening and Cleaning -368808
    DIY Honda City 04-08 Instrument Cluster Opening and Cleaning -368810
    DIY Honda City 04-08 Instrument Cluster Opening and Cleaning -368815
    DIY Honda City 04-08 Instrument Cluster Opening and Cleaning -368816
    DIY Honda City 04-08 Instrument Cluster Opening and Cleaning -368818
    This is how the speedo looks after you remove the rings, the red coloured circles show the screws u need to remove now:
    DIY Honda City 04-08 Instrument Cluster Opening and Cleaning -368825
    After these four screws come off, U can now remove the "lower" side of the "roof" above the speedo.
    Once, removed, the speedo will now look like this, the circles again show the screws to be removed next:
    DIY Honda City 04-08 Instrument Cluster Opening and Cleaning -368828
    Now, The other half of the "roof" can be taken off as well. You'll see two Grips, Blue and green. Pull them out (they may seem a little extra hard) and now the speedo can be simply taken out.
    Here is the speedo out:
    DIY Honda City 04-08 Instrument Cluster Opening and Cleaning -368832
    DIY Honda City 04-08 Instrument Cluster Opening and Cleaning -368833
    With the speedo out, you can easily remove the lens. It uses a few clips to stick.
    While cleaning the cluster, be extra cautious with it as it is very very delicate and can be easily damaged. Try ur level best not to touch the needles.
    I used STP SUN OF A GUN to clean the speedo and it worked awesome for me.
    and I would strongly suggest not to open the speedometer's internal wirings as it is sealed. Once opened, it may become damaged and can cause serious issues. Only try to do it if u really now what u're doing.
    I will post how to put back the "tricky screws" back in.
    Some more pics after I put it back in are continued...
    I got these haters like, "when is he gonna stop?" Maybe a minute after never so set your clocks.
    Oct 2011
    3,870
    48 Post(s)
    19 Thread(s)
    This is how to put back the tricky screws. be very very careful as if u lose the screw, it can be really hard to get it back from inside the dash.
    I scotch taped the screw to the screwdriver and then aimed it straight in...
    DIY Honda City 04-08 Instrument Cluster Opening and Cleaning -368839
    Few pics after I put it back in:
    The lighting has increased more than 50%...!
    Will post day-time pics tomorrow, inshAllah.
    DIY Honda City 04-08 Instrument Cluster Opening and Cleaning -368840
    DIY Honda City 04-08 Instrument Cluster Opening and Cleaning -368841
    DIY Honda City 04-08 Instrument Cluster Opening and Cleaning -368842
    Oct 2011
    3,870
    48 Post(s)
    19 Thread(s)
    The same technique applies to the city steermatic 06-08 instrument cluster as well. The difference is only in the speedometer itself.
    accord7362 and smashhud like this.
    smashhud's Avatar
    Jun 2011
    33
    613
    2 Post(s)
    Hmmmm... The lovely Optitron Speedometer of Steermatic is my favorite thing in the car... I am not sure I am gonna try this any time sooner though
    accord7362 likes this.
    A man is known by the ride he keeps!!!
    Oct 2011
    3,870
    48 Post(s)
    19 Thread(s)
    Smile
    Quote Originally Posted by smashhud View Post
    Yea... its lovely for sure. And bro ur car is only 43k driven. U don't need to do this. Ahmad bhai needs to do this badly and so do a few fellow idsi owners.
    ur black jack is indeed a CLEAN steermatic. And i've heard that one can buy Steermatic style optitron meter for manual idsi easily. I am in search of that...
    accord7362 and Vajih102 like this.
    smashhud's Avatar
    Jun 2011
    33
    613
    2 Post(s)
    Thanks for the appreciation Dear.. I do try to keep my ride as stock as possible.. and its 46K driven now ...In theory Steermatic's meter should fit any iDSI... Lets wait till you or anyone else practically does this
    coolsmart's Avatar
    Jun 2010
    Attock
    31
    245
    3 Post(s)
    Good work although explained by A_N_memon but picts speaks louder.
    Oct 2011
    3,870
    48 Post(s)
    19 Thread(s)
    Smile
    Quote Originally Posted by coolsmart View Post
    haha... Thank you. actually the confusion was how to open. And a good way to reinstall the screws. Rest is pretty easy.
    BTW, I was thinking the other day about you,Long time no see?
    ahmadbila's Avatar
    Aug 2005
    Sargodha
    22
    11,621
    32 Post(s)
    5 Thread(s)
    Mama jee chaad gae hain aap im the next person whos gonna do this
    (Putting link of this thread in Honda city fan club main post)
    When the power of love exceeds the love for power, the world will finally know peace=Every man is guilty of all the good he didn't do
    Oct 2011
    3,870
    48 Post(s)
    19 Thread(s)
    Smile
    Quote Originally Posted by ahmadbila View Post
    Sir G, Thank you...
    And the bold face thing is an honour for me... I hope I see u doin it soon.
    hash4u's Avatar
    May 2005
    34
    19,161
    18 Post(s)
    4 Thread(s)
    thats a good DIY!
    thanks for sharing
  12. #12
    Oct 2011
    3,870
    48 Post(s)
    19 Thread(s)
    Smile
    Quote Originally Posted by hash4u View Post
    thats a good DIY!
    thanks for sharing
    Thank you bro... Means alot.
  13. #13
    ahmadbila's Avatar
    Aug 2005
    Sargodha
    22
    11,621
    32 Post(s)
    5 Thread(s)
    Quote Originally Posted by RollOnBigMaMa View Post
    Sir G, Thank you...
    Already done sir jee
    and as far as steermatic cluster is concerned, theoratically, YES, we shud be able to fit it into an idsi but u know, it has an indication of gears engaged "PNDRL" etc and also 1,2,3,4,5,6,7 if the manual mode is turned on... i wonder what can be done about that... but YES, it would be awesome if someone can find a manual transmission cluster that used to come in 1.5l abroad, thailand japan india etc...
  14. #14
    ahmadbila's Avatar
    Aug 2005
    Sargodha
    22
    11,621
    32 Post(s)
    5 Thread(s)
    yar how exactly did u clean the dirt inside it? u used STP for shine but how did u actually wipe off the dust? specially around the delicate areas i.e. around the needles (did u move them?) and the dust that was actually sitting on the needles? im planning to use cotton buds to clean the delicate areas. what did u use? damp cloth? dry cloth? air pressure?
  15. #15
    ahmadbila's Avatar
    Aug 2005
    Sargodha
    22
    11,621
    32 Post(s)
    5 Thread(s)
    and oh, so the tip to take off that rings thing is just a LOT of force, right? properly distributed... ???
  16. #16
    Oct 2011
    3,870
    48 Post(s)
    19 Thread(s)
    Umm humm, I was talking about yu cleaning ur cluster...
    and yeah, for the steermatic cluster, hmmm, well we can always put it practically as well IF the grips and wires are the same as idsi and I am pretty sure that they are cz paki people don't like much difference between two variants of the same car. The PRNDS lights will simply not light up in this case.
    but I was wondering if may be some AWESOME electrician can hook up the 1234 lights to our manual gears .
    Ahhh, would that I was an engineer!!!
    and I have already began to search for a Manual tranny cluster on the internet. I bet we can get it shipped from abroad. See what I can do. When I come across one, I m gonna be ordering one for 1451 as well...
    Hmmm. Well, actually, the inside of the cluster is somehow very sticky type of thing. Esp the dials. One uses a "not so good product" and he may end up in a very sticky situation.
    Well, I used STP for the cleaning all over. Took a bit of tissue and wiped the dials gently with it. Used a cotton bud for the needles.
    The needles are very very light and they move just by blowing air onto them. Tried my best to keep them stationary.
    No cloth or cotton whatsoever cz I found that fibers stick to the dials very easily and they look YUCK in the light.
    And finally before Putting the lens back, I used my mum's (very) fast hair dryer to move away any dust particles that fell into it. Whoalla. All done.
    Yes the basic tip is that very thing. A lot of force but with a LOT LOT of care and precision. one mistake and "klick"
    But the rings are not THAT delicate. They are pretty firm and good made.
  17. #17
    ahmadbila's Avatar
    Aug 2005
    Sargodha
    22
    11,621
    32 Post(s)
    5 Thread(s)
    oh, i ll be doing it very soon yaaar... dont u worry
    yeah sure man, i give u the "go ahead" for ordering one for 1451 too, then hopefully we wud have the ONLY idsis with steery tachos installed
    hmmm... i see... so what u did was
    1) wiped the dials with tissue paper
    2) used STP for shine..
    or was it in reverse order? im gonna get me an STP thingy too... never used it before... and yaaarr... dont scare me, "click" ho gae tou waat lag jaegi
    Vajih102 likes this.
  18. #18
    Oct 2011
    3,870
    48 Post(s)
    19 Thread(s)
    Smile
    InshAllah. Just pray that I find the proper tachos and then they install in our cars without much glitches.
    And dun be scared. Nothing that scary... Maine b andha dhund zoar laga k rings to khaincha tha. Socha tootna hai to toot he jaye ga na.Edi keri gal aa? But manhoos ka patta toh chalay ga k khulta kaise hai.
    Yes I did exactly the same. Infact, I dipped a small tissue in STP and wiped the dials with it again. As STP leaves stains if applied unevenly. Moreover, i didn't want any DUSTY HAVOC in it by using excess.
  19. #19
    Oct 2011
    3,870
    48 Post(s)
    19 Thread(s)
    Ahmad bhai, one more thing, About the central console respray.
    I busted the little chrome strip in the handle of the tray. I pasted some masking tape and when I removed it, the strip, basically a sticker, Also came off. . I still have it with me. But anyways to restore it?
  20. #20
    Oct 2011
    3,870
    48 Post(s)
    19 Thread(s)
    Check these out... I bet i can find these, inshAllah.:
    DIY Honda City 04-08 Instrument Cluster Opening and Cleaning -370164
    DIY Honda City 04-08 Instrument Cluster Opening and Cleaning -370165
    DIY Honda City 04-08 Instrument Cluster Opening and Cleaning -370166
    smashhud likes this.
Similar Threads
  1. 95 Civic Cluster Cleaning.
    By shazo in forum D.I.Y Projects
    Last Post: 26-10-2012, 01:47 PM
  2. For Sale: AE92 Corolla Digital Instrument Cluster (very rare!)
    By KiwiCorolla in forum Body / Lights / Appearance Parts
    Last Post: 18-09-2012, 10:00 PM
  3. WTB civic 05 electronic instrument cluster
    By sherrypizza in forum Body / Lights / Appearance Parts
    Last Post: 03-10-2011, 11:05 PM
  4. Instrument Panel Brightness - 2008 Honda CIty IDSI
    By fhs1111 in forum Car Entertainment / Electronics / GPS Navigation
    Last Post: 29-06-2011, 10:41 PM
  5. How to replace instrument cluster bulbs on a Cuore?
    By Spartacus in forum Electrical / Wiring / Battery / Lights
    Last Post: 09-09-2010, 05:52 PM
Tags for this Thread
