yes it is and has much much thicker axles too - because the GZE is all about supercharged torque, you need a meatier flywheel and stronger clutch to keep up.
the A block is similar, stuff fits easily, but its not recommended to do that because the GZE has a lot of grunt. Too much twist going down the driveline. Better to get an automatic and build it for racing use.
