Anyone who knows whethers OBD-II scannered equipment and associated available in Pakistan.
ELM327 Interface Bluetooth OBD2/EOBD Auto Scanner.
The program lets you perform the following operations
Read diagnostic trouble codes, both generic and manufacturer-specific, and display their meaning (over 3000 generic code definitions in the database)
Clear trouble codes and turn off the MIL ("Check Engine" light)
Works with all OBD-2 compliant vehicles
Bluetooth connection
LED indication
Voltage: 12V (short circuit and overvoltage protection)
Comes with CD disk
Display current sensor data, including
Engine RPM; calculated load value; coolant temperature; fuel system status; vehicle speed; short term fuel trim; long term fuel trim; intake manifold pressure; timing advance; intake air temperature; air flow rate; absolute throttle position; oxygen sensor voltages / associated short term fuel trims; fuel system status; fuel pressure; many others
