Community Forum Actions
Page 1 of 2 12 LastLast
Results 1 to 20 of 21
Like Tree10Likes
Thread: Civic 2012 starting problem
    imbigsmall's Avatar
    Jul 2012
    431
    Unhappy Civic 2012 starting problem
    Assalamualaikum everyone!
    Alhamdulillah, I got my 2012 civic in silver last friday! But i noticed a small problem. Whenever i turn the key from the battery/on (whatever) mode to start the engine, NOTHING HAPPENS! i turn it again and then only the engine starts. I experimented with the problem several times by waiting a while and then turning the key or turning the key immediately. But the problem persists in every way. It has'nt even been driven over a 100 kms and it's making me worried. Is it a big problem? Can it be fixed easily?
    Help would be appreciated
    capsat's Avatar
    Apr 2006
    4,431
    2 Post(s)
    your 2 mil worth Honda is under warranty as Owner you shall pay a visit to Honda dealership and ask to get it fixed under warranty. any tweek done on your own will VOID the warranty
    on other side
    after 2 clicks there is an spring action which is IGNITION mode to start the engine only 2 click will activate all systems & next push will crank if not then its something to worry
    Please read --> http://www.pakwheels.com/forums/site-feedback-suggestions/181978-attention-mods
    Xulfiqar's Avatar
    Aug 2003
    Houston
    34
    12,879
    140 Post(s)
    11 Thread(s)
    Did Honda go oldschool again, If anyone has driven the old 3rd and 4th gen accords and even the old 3rd and 4th gen civics - they will remember that you were supposed to push the key inwards while turning to start, if you did not push the key only spun 98% of the way and did not make starter signal contact, only when the key was pushed inwards and twisted to start it would spin 100% and make the engine start.They even had a sticker on the column cover it that said "PUSH -->" with the arrow in the direction of start.
    capsat likes this.
    ZRS - Zulfiqar Racing Systems ..... PROFESSIONALS at WORK at CRACKWHEELS.COM
    chinyoti's Avatar
    Sep 2005
    23
    10,193
    30 Post(s)
    2 Thread(s)
    Probably some imobilizer/Coding issue with the key, Getting it check by the dealership would be the right choice. Do you see any (key) mark in the meter cluster, While it doesnt starts?
    Alinaseem and qwertypoiu like this.
    Get over the fact that Xli lacks power windows, Its an Xli because it lacks thoose features or else it would be a Gli or an Altis if had all the goodies.
    imbigsmall's Avatar
    Jul 2012
    431
    Quote Originally Posted by capsat View Post
    on other side
    Hmm... Maybe I should pay them a visit. Even my steering wheel isnt aligned perfectly. But thanks anyway though!
    imbigsmall's Avatar
    Jul 2012
    431
    Quote Originally Posted by chinyoti View Post
    I don't think it's a problem related to the immobilizer. No, there's not any light, relating to the immobilizer, glowing. And yes, I might visit them in a few days. But just thought of sharing this with you guys!
    imbigsmall's Avatar
    Jul 2012
    431
    Wasn't it the other way around? I mean before turning the key to off mode to pull it out we had to push it inwards and then backwards. There is still a <-- Push mark drawn there!
    Xulfiqar's Avatar
    Aug 2003
    Houston
    34
    12,879
    140 Post(s)
    11 Thread(s)
    both ways - my car had a push --> mark to lock the steering and pull out the key you needed to push it and twist back, to start you needed to push and twist
    imbigsmall likes this.
    jah
    jah is offline
    jah's Avatar
    Oct 2005
    24
    229
    imbigsmall's Avatar
    Jul 2012
    431
    Wow! Fancy, I would say!
    Xulfiqar's Avatar
    Aug 2003
    Houston
    34
    12,879
    140 Post(s)
    11 Thread(s)
    OP - take it to Honda, most probably the starter switch at the back of the ignition barrel has some fault, if it were the key the car would completely refuse to do anything.
  12. #12
    raza1's Avatar
    Nov 2006
    37
    3,474
    Ignition problem, steering not alligned, if ur car has PDI ok sticker then ask them what the F that means?
    Sent from Jail using Tapatalk
  13. #13
    Xulfiqar's Avatar
    Aug 2003
    Houston
    34
    12,879
    140 Post(s)
    11 Thread(s)
    PDI on that means = peekay dramabazi ki inspection
    Alinaseem, dms664 and imbigsmall like this.
  14. #14
    bilal49er's Avatar
    Jan 2005
    Hyderabad
    37
    1,370
    Buddy if its an auto, make sure ur starting it in N or P only. It will do exactly what ur describing if u attempt to start in any other position.
    sent from my HD2 without using the handset itself!!
  15. #15
    imbigsmall's Avatar
    Jul 2012
    431
    True...!
  16. #16
    imbigsmall's Avatar
    Jul 2012
    431
    Quote Originally Posted by raza1 View Post
    I know right! Maybe they just put the PDI sticker on every Honda
  17. #17
    imbigsmall's Avatar
    Jul 2012
    431
    Quote Originally Posted by bilal49er View Post
    Yes it is an auto tranny, but I always start it in P. I wonder why the problem persists
  18. #18
    raza1's Avatar
    Nov 2006
    37
    3,474
    The starting problem has nothing to do with P and N i guess. In P position the car is in N with wheels jammed.
  19. #19
    bilal49er's Avatar
    Jan 2005
    Hyderabad
    37
    1,370
    the engine will only turn with key IF its in N or P. if at any other position, the lights will go off and nothing will happen
  20. #20
    raza1's Avatar
    Nov 2006
    37
    3,474
    Agree with you bilal. I misunderstood ur previous post.
    bilal49er likes this.
Similar Threads
  1. History of Automobile Industry in Pakistan
    By waqasramay in forum Wheels in Pakistan
    Last Post: 12-01-2011, 05:28 PM
