My car can b seen on DP. I have this ride since 2012 but there is a problem which i encounter every winter season, front screen defogger is not working properly despite switching front air control to Fresh Air and blower direction towards front screen. Even then, the screen remains foggy and i have to use tissue paper to wipe it out. What can be the issue with my car can any body have an idea please do share.
Click here for SOLUTION
1- is the blower working towards the windscreen? you can check it by placing your hand on the vents2- in winters, turn the blower towards windscreen and turn on AC, the screen will be clear in few seconds
^^^^^^ Perfectly summed it up.
ac is not working in my car. but both other things have already been done even then screen remains foggy. and i have to use towel to wipe out fogg.
When you want to use front defogger, use fresh air, not recirculated air.Always use recirculated air when AC is on in the summer.
That is the problem. Get the AC fixed because to defog front wind svreen you need to switch it on and set the temperature in the white zone.
Do you use hot air or fresh air?
bro then the best way for you to keep the screen defogged is to keep both front windows open a bit, just 1.5inch on both the sides would be enough!
Nice suggestion.
thanks bro
defogger requires you run the A/C with heat mixed aimed at the windscreen glass.
Or you can try the following products (if available locally).
http://www.amazon.co.uk/Pro-Vision-Fog-Clear-Gel/dp/B002PHXC1K/ref=pd_sxp_grid_pt_2_2
http://www.amazon.co.uk/Permaclear-Stayclean-Antimist-Spray-500/dp/B0085XNDSA/ref=pd_sxp_grid_pt_2_0
This is available at Hyper Star in Lahore.. perhaps you can find it in isloo too..
http://www.amazon.co.uk/Astonish-C1531-750ml-Anti-Fog-Cleaner/dp/B004WODLJW
