Aoa members i have a questiin regrading elm327...can i use it with my car?my car has 3pin dlc and mechanix used to connect 3pin to 16dlc adaptwr to connect scanner... Ecu of my car is p3x k01. Its very rare ecu i heard somewhere it is obd2a... If anyone tested pakistani city/civic 2000elm 327 thrn kindly tell me
why ?? just short the pins and count the blinking lights to trace the error. i have the exact method posted somewhere on the forum.
even if u do end up connecting the scanner. you will get very few readings as your ecu is obd1
Is any test elm327 with 3 pin dlc to 16 pin obd in civic 99 vti auto? This port require external K line power. How to give power in elm327 for operation?
For real time sensor data monitoring ...o knw the method to diagnose fault code....
Any test result would result in extremely thanks
