salam everyone i recently bought philips extreme vision bulbs i am getting very poor visibilitymy headlights are of low quality i bought them for 1500rs 6 months agonow i searched about depo headlight can anyone tell me from where i can get these and what will they cost?
put Colgate tooth past on it n buff it a lot.
Bro i got them buffed from a bumper guy they are crystal clear but dont give proper results
Sent from my iPhone using Tapatalk
You're in Islamabad , if you'd have been in lahore then i would have suggested you to visit bilal gunj or mintgomery road
check you car voltage. or add relay two relay for two lights.
I paid 1500 rs electrition used new wire plus 2 relays for headlights all new wiring still no luck
from where did you buy bulbs and what is the wattage?
bro i bought from a reliable source from karachi bulbs are genuine its 55/60 w
These are pics of lights
H4 koito original 90/100 bulbs are the best in normal category based on my experience
my HID's tube got fused. What should i check while buying a new one for same type of light i.e. which it was later before fusing. I went to Montgomery road. Peoples are thug. One person quoted me 2,200 for Tube change. When i refused he left and the other person standing beside us said same tube he can arrange in 800 all inclusive. I got confused and went back
inquire price of OEM headlights from a Suzuki dealership or parts dealer if they are reasonable then go for them otherwise depo
nothing will perform as good as original headlamps, and that is what i recommend. No idea of depo. but have you checked your wiring? it could be low voltage or bad aim.
What bulbs were you using previously?
Originally cultus comes with osram bilux.
Before this i was using hids Guy put a new wire with 2 relays
never underestimate stupid :D, get a voltmeter to be sure. must have tool anyways
i hv same problem with my cultus, i changed whole head lights, but problem persist, which i use bulb or other suggestion for my cultus, road side way not look clear, and light is also dim, plz also suggest me
what bulbs are you using ? If using local or chinese then get the original kioto ones or Osram also your headlights might not be aligned properly get it checked aswell
All aftermarket depo , tyc etc lights have visibility problem bettet go for original lights no matter old
I checked frm a source original headlights costs 15000rs I m not going to spend that much just on visibility A guy told me he can arrange depo pair for 5400rs i m thinking to go for that What are your suggestions
Bro if i get voltmeter how i can check wiring is proper
