Chevrolet Spark P0601 Engine Trouble Code
Chevrolet Spark P0601 Code Meaning :P0601
OBD-II Diagnostic Powertrain (P) Trouble Code For Engine
Intake Valve Control Solenoid Circuit Low
Fuel Temperature Sensor B Circuit Range/Performance
Cold Start Injector 1 Malfunction
Crankshaft Position Sensor A Circuit Low Input
When you check Chevrolet Spark car engine light came on code P0601 the reason should be Engine Light ON (or Service Engine Soon Warning Light).
However manufacturer may have a different definition for the P0601 OBD-II Diagnostic Powertrain (P) Trouble Code.
So you should chech it on our car models.
P0601 Fault Symptoms : check engine light comes on Engine stalling or misfiring Engine performance issues Car not starting
If one of these reasons for P0601 code is occuring now you should check P0601 repair processes.
Now don't ask yourself; What should you do with P0601 code ?
Chevrolet Spark P0601 Possible Solution :
Disconnected, dirty or fouled spark plugs are common causes for engines
that won't start. Spark plugs typically need to be replaced every season
or 25 hours of use. You should also check that the spark plug gap is
set properly. If your spark plugs look good, problems with your ignition
system can also preventing a spark. These can range from a faulty spark
plug lead, shorted kill switch or flywheel key damage.
P0601 OBD-II Diagnostic Powertrain (P) Trouble Code Description
P0601 OBD-II Trouble Code There is a problem with the P0601 code.
Reason For P0601 Code
The reason of P0601 OBD-II Engine Trouble Code is Fuel Temperature Sensor B Circuit Range/Performance.
Parts or components should not be replaced with reference to only a
P0601 DTC. The vehicle service manual should be consulted for more
information on possible causes of the fault, along with required
testing.
Source: http://p0601.enginetroublecode.com/chevrolet-spark
