I drove my car in last night, absolutely no problem whatsoever.
I sat in my car today and noticed that the clutch went all soft and spongy(no resistance), but it did spring back up. This has happened once or twice before and the immediate remedy was to start the car and give the engine a good throttle and all would be good again.
So I tried starting the car, and I hear a little pop sound like some sort of pressure release.
I check around for any leaks, nothing.
Tried starting the car again and it just wouldn't start (self lerahi hai but just won't start).
So I pressed really hard down on the clutch pedal and I get some freedom to shift my gears, so I went in and tried starting the car .....
Now the car is jammed in the first gear, clutch is still useless as ever, and ab self bhi nahi lerahi.
It feels like trying to start you car in first gear with a partial pressure on your clutch, it gives like a jerk but self nahi lerahi.
Apart from calling the mechanic over and emptying my pockets, is there anything I could do or check ?
Thank you :3
