AoA Bostupthecar!
I need help regarding my baleno. as it is not starting. On ignition the vehicle cranks but not starts, local mechanics have checked and all have different views some say there is float problem, some say the ECU is faulty. Actually when the ignition key is turned on all lights appear, and check engine light blinks vehicle cranks but current does not come to the coil. Would be really thankful if you could kindly help on the issue.
