Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: CHECK ENGINE light in Baleno, URGENT HELP NEEDED PLEASE!!!
    PakWheeler's Avatar
    Dec 2005
    31
    183
    Default CHECK ENGINE light in Baleno, URGENT HELP NEEDED PLEASE!!!
    Guys,
    The check engine light in my baleno and on and RPM is very unstable, i mean first on low RPMs the car would shut and now....when i start the car...the RPM is automatically very high, i dont even have to press the accelerator, just leave the clutch and cars in movement.
    I am in Islamabad, PLEASE advice me to WHOM i should i go? no guy i know could fix it, they seem to know NOTHING about this.
    Please help!!
    i look like a beast, i lift like a beast, i eat like a beast...i am probably a beast!
    fyq
    fyq is offline
    fyq's Avatar
    Jan 2008
    29
    2,146
    8 Post(s)
    ist of all. scan it on computer ! thn go to any mechanic !
    let the music play
    PakWheeler's Avatar
    Dec 2005
    31
    183
    scan it on my pc? tell something precise or refrain from posting mate.
    Civic_Crazed's Avatar
    Mar 2010
    34
    10
    Yar ve seen this problem in many balenos. I had a baleno and it also used to do this occassionally. Get the throttle body checked and Throttle position sensor as well. Might work for you.
    PakWheeler's Avatar
    Dec 2005
    31
    183
    Civic_crazed
    thasks a bunch. I just remembered a while i got the throttle body cleaned and my lord, the car simply flew!
    DO u live in isb? any good mechanic who can replace the censor?
    irfansiddique's Avatar
    Oct 2008
    31
    1,691
    11 Post(s)
    is ur car on cng ?
    seems like a throttle body problem to me.
    or maybe ur MAF sensor is not working properly.
    Mar 2010
    34
    10
    Yar. M in Karachi and why you are not taking it to any suzuki dealership to get this done. They are expensive though but get the job done for you. Waisay frankly speaking, i always try to stay away from dealerships but when you have no other good choice, they are the only choice.
    khahsan's Avatar
    Jan 2007
    33
    1,587
    go to g-10, there is an enercon workshop and the guy there is really professional. just tell him to tune up the car. woh khud he beemari b pakar lay ga aur ilaag b ya tu bata day ga ya kar day ga...
    argtr65's Avatar
    Dec 2008
    49
    1,488
    43 Post(s)
    6 Thread(s)
    Throttle position sensor (TPS) needs cleaning,get it cleaned.
    Never loose hope in life,every step gives u something.
    Site Banned Follow
    vicky258's Avatar
    Apr 2010
    26
    12
    Mod edit: for commercial selling on pakwheels and for advertizing please contact the administrators
    chinyoti's Avatar
    Sep 2005
    25
    11,111
    65 Post(s)
    4 Thread(s)
    r u saying the check light comes and the RPM goes up? or its as it is.
    jahan tak i noe in Baleno check light doesnt comes on if the TPS sensor needs cleaning. Its probably a bad calm shaft sensor (distributor sensor) as u said u had unstable RPM its probably means that either the sensors dead or theres some kind of short circuit.
    If u have a after market cng installed usually CNG people give current to the advancer from the possitive wire of the Calm shaft sensor causing the short circuit resulting in failure of the calm shaft sensor and unstable RPM.
    but its better u take it to a complete workshop who have a OBD device and scan ur cars computer to diagnose the actual issue.
    Get over the fact that Xli lacks power windows, Its an Xli because it lacks thoose features or else it would be a Gli or an Altis if had all the goodies.
  12. #12
    madhouse12's Avatar
    May 2007
    Rawalpindi
    36
    7,667
    207 Post(s)
    7 Thread(s)
    The best baleno guy i know is on Shallay valley road past qasim market area in Rawalpindi. the workshop is called Madeena filling station and the guys there are Azhar and Mazhar.
  13. #13
    imdachosenone's Avatar
    Aug 2009
    45
    17
    Same happened with me. I changed my batteries and the RPM sky rocketted afterwards. Went to Suzuki motors in ISB the "good for nothing" diagnostic tool told Throttle body sensor error (" there is not throttle body sensor"). Anyway got it cleaned it had some problems but problem persisted. After 2-3 weeks it dissapeared automatically.
  14. #14
    ngen's Avatar
    Oct 2008
    36
    166
    I have an obd scanner in my shop ... if you want come over and i'll let you know the cause. check my website for address details.
  15. #15
    Skill's Avatar
    Aug 2009
    Other
    7,777
    80 Post(s)
    38 Thread(s)
    Quote Originally Posted by ngen View Post
    i need exact meanings of O B D ? ? ?
    https://www.facebook.com/skillgrafik
  16. #16
    ahmadbila's Avatar
    Aug 2005
    Dubai
    24
    12,497
    86 Post(s)
    11 Thread(s)
    Quote Originally Posted by Skill View Post
    On Board Diagnostics.
    Its basically a part which lets u connect u a computer or a diagnostic tool to ur computers ECU and reads of a code which caused the CHECK ENGINE light to turn on.this code is then looked in the reference book which explains what exactly went wrong in the car and where.... there are sensors in many part of the engine, like air intake, exhaust etc which are feeding data every fraction of second, if the data they feed doesnt match the standard setting the car is desgined to work on, the CHECK ENGINE light flashes.
    When the power of love exceeds the love for power, the world will finally know peace=Every man is guilty of all the good he didn't do
  17. #17
    ngen's Avatar
    Oct 2008
    36
    166
    ahmadbila is right.
  18. #18
    ahmadbila's Avatar
    Aug 2005
    Dubai
    24
    12,497
    86 Post(s)
    11 Thread(s)
    here r sum pix of the thing... its attached to a port located sumwhere beneath ur steering consol or near it, under the dashboard.a computer with a special software is used to carry on the job, but a simpler OBD 2 scanner is also available.which is just a small calculator like device which tells u the error code.
    here r sum pix that might help u under stand.the software on computer shows realtime stats about the engine.
    CHECK ENGINE light in Baleno URGENT HELP NEEDED PLEASE!!! -74148
    CHECK ENGINE light in Baleno URGENT HELP NEEDED PLEASE!!! -74149
    CHECK ENGINE light in Baleno URGENT HELP NEEDED PLEASE!!! -74150
  19. #19
    Bilaltq's Avatar
    Mar 2004
    Select City
    24
    10,308
    8 Post(s)
    The check engine light could be on because of just one error code that came in at some moment, and the light won't go away until that error code is cleared.
    If you want to be very precise to find out what your problem is, then you can have the car scanned using an OBD II scanner tool... I would have no idea where you could find one. I have a hunch that the suzuki dealership would have one- they'll charge you I can bet, but that's up to you if you want to use this option. I hardly ever give a crap about what the scanner tool says because... for god's sake, I have the internet as a resource, and I've been able to diagnose every problem to ever hit my car with a simple google search.
    Plan B (or A for me) is to do it the ghetto way and take off the negative terminal of the battery and leave it off for about a minute or so. Doing so would clear the error code that caused the CEL to be on in the first place (exactly the same way the clock goes back to 1200 after you disconnect the battery) Put it back on and start the car, see if the check engine light is still there. If it is, you know for certain that a sensor needs to be replaced- in all likelihood, it will be the throttle position sensor.
    Here are some symptoms to a bad throttle position sensor:
    Symptoms of a Bad Throttle Position Sensor
    This comment was made by a person with a tested IQ of negative 9.
  20. #20
    asadsrc2003's Avatar
    May 2005
    Gujranwala
    27
    276
    2 Post(s)
    I own a Baleno too, it happened to me as well. And the reason behind was that I used A/C for 30 mins, while my car was stable (parked). and the problem of CHECK ENGINE light got fixed when I drove my car for 100 km. And i faced this problem for 2 days.. Now it's going great!!!
    aDdi0z
Similar Threads
  1. "CHECK ENGINE" Light - Baleno
    By Noushad in forum Engine / Transmission / Powertrain
    Last Post: 14-03-2010, 08:03 PM
  2. ENGINE CHECK LIGHT?
    By Shogun78 in forum Engine / Transmission / Powertrain
    Last Post: 05-03-2009, 11:56 AM
  3. Engine Check Light
    By hingorian in forum Engine / Transmission / Powertrain
    Last Post: 17-12-2007, 12:56 PM
  4. check engine light
    By Bilall in forum Engine / Transmission / Powertrain
    Last Post: 28-06-2007, 12:20 PM
  5. check engine light is on ?
    By ahad15 in forum Car Entertainment / Electronics / GPS Navigation
    Last Post: 04-08-2006, 01:51 AM
