@xulfiqar
I dont exactly remember the caliberated pressure of the nozzles but it was either 120 or 220 PSI if i am not wrong.
I am not sure about unit (it must have been PSI).
Please confirm if 220 PSI is ok for toyota 2C?
Also i started using zic 5000 CI4 standard oil since last 1.5 year and i have observed that after start up the oil light takes more time than usual to turn off.
Car pick is way good and after using no smoke of Liqui moly and running is ever smooth along with idle nothing abnormal.
I have over taken reborn on motorway myself at 152 KM/Hr and car was still accelerating when i lift off. And there was no cloud of smoke at the back however small stream which i think is normal as u have said at full throttle.
