Page 1 of 2 12 LastLast
Results 1 to 20 of 23
Thread: Baleno Check Engine Light
    umartahir's Avatar
    Jun 2011
    Faisalabad
    33
    9
    Default Baleno Check Engine Light
    Hello All:
    I live in Faisalabad and have a baleno 2004. From last 4 days, it is creating problem on CNG. When i leave my house for some market or any other place, it ON the check engine light. Jb bhi check engine light ON hoti hy, gari jhatka marti hy. Phir thek ho jati hy. But throughout the jorney, this happens many times. I went to many workshops. Some said, that it is CNG poing issue (that is near stearing, where we see CNG lights). Another said, KIT and Cylinder ki service ho gi. Some said that We'll change advancer and whole wiring and it ll cost 9,000.
    I have to go to Islamabad by the end of this month. And i cant go with this problem. I have to solve this please.
    So kindly tell me that Can any one of you solve my problem?
    fullyloaded2's Avatar
    Mar 2008
    30
    129
    dude its a sensor issue, if u can come to isbd i can guide u to the cng mechanic who solved the same issue on my baleno.... cng kit and cylinder has nothen to do with it....
    umartahir's Avatar
    Jun 2011
    Faisalabad
    33
    9
    Dear, issue is same. I cant come to islamabad without solving it.
    Please can you please tell in explain that which sensor.
    roms's Avatar
    Feb 2011
    31
    3,036
    93 Post(s)
    Sounds like the air temperature sensor or throttle position sensor is going bad. Visit any 3s and pull out the error codes, so u know what exactly it is
    They see me rollin'............
    umartahir's Avatar
    Jun 2011
    Faisalabad
    33
    9
    Ok Dear, i ll check and tell you later.
    Thanks
    saadz137's Avatar
    Jun 2006
    28
    132
    This is No Issue .... If you want you can drive as much as u want with this Check Engine light , it wont affect anything in the vehicle , I had the same issue in my Baleno 2005 , what i did was get the wires of the Injectors changed(Wires which supply current to injectors) n thats ittt .... Issue resolved , It should cost u 150 to 200 Rs
    roms's Avatar
    Feb 2011
    31
    3,036
    93 Post(s)
    Quote Originally Posted by saadz137 View Post
    When the CEL comes up the car goes in kind of safe mode and won't run on full potential. In this mode, the engine runs at predetermined settings till it is diagnosed and repaired.
    saadz137's Avatar
    Jun 2006
    28
    132
    @Rom
    As far as my experience is confirmed , i dint find any jerk in the drive or any difference when the check engine light is on or off , In my case there was bad wiring that caused the light to turn-n , rather then wirings affect on engine that actually causes the light to turn on , soo might be the case with the poster as well , I think he should give it a try with a differenst set of wires n check.
    roms's Avatar
    Feb 2011
    31
    3,036
    93 Post(s)
    @Rom
    True, but poster should pull out the codes first, may be something else,
    chinyoti's Avatar
    Sep 2005
    25
    11,297
    78 Post(s)
    4 Thread(s)
    Step wise check it.
    1) Convert your car to petrol, Does the check light stays?
    2) Open the bonnet increase the throtle slowly, Is there any missing at initial rpms.
    3) Remove all the plug wires and coils one by one, Does the car stutter by removing any of them.
    4) Remove the distributor sensor wire (calm shaft sensor) is there any change.
    5) The main issue is that sensor, If your car is on after market CNG mechanice plug the advance thru that sensor, not proper fitting might burn that wire creating a short circuit due to which your cars Advancer and the sensor both arnt working. Resulting in slugish drive on CNG, and a problematic drive on Petrol.
    Baleno does not give a check light if driven on CNG so its definetly a electronic fault. As you mentioned is missing as well, so its probably the sensor thats faulty or the wiring to the sensor isnt working.
    Get over the fact that Xli lacks power windows, Its an Xli because it lacks thoose features or else it would be a Gli or an Altis if had all the goodies.
    chinyoti's Avatar
    Sep 2005
    25
    11,297
    78 Post(s)
    4 Thread(s)
    Default location of the sensor
    Baleno Check Engine Light -253452
  12. #12
    umartahir's Avatar
    Jun 2011
    Faisalabad
    33
    9
    Dear saadz137:
    Yes I can drive car as far as i want, but with jhakty, not smooth and the light on and off frequently.
    Dear Chinyoti, i really appreciate your soulutions on different threads. Yes i ll check the sensor too.
    It is ok on Petrol, really no issue.
  13. #13
    umartahir's Avatar
    Jun 2011
    Faisalabad
    33
    9
    Dear chinyoti and other fellows:
    1 more question with you all. When we heard that someone checks the car with attaching the computer with it, then where he attachs the port in the baleno?
  14. #14
    chinyoti's Avatar
    Sep 2005
    25
    11,297
    78 Post(s)
    4 Thread(s)
    ^ check when the car is standing idle, increase the race slowly between 1000rpm to 3000rpm see if theres any missing, yes the missing only on initial rpms not and feels okay above 3000rpms
    The port is attached under the steering colum, if u are on ur knees and u sit out side the car, you can see it just under the dashboard.
  15. #15
    umartahir's Avatar
    Jun 2011
    Faisalabad
    33
    9
    Yes sir jee, there is missing in initial RPM on Petrol, not on CNG. But that is, i think due to the injectors. One of the injector of my car is faulty as mechanics said.
    Can you pleeease send the pic of the port, under steering column. I searched but not found. Picture please....
  16. #16
    chinyoti's Avatar
    Sep 2005
    25
    11,297
    78 Post(s)
    4 Thread(s)
    sold my Baleno but il try googling. Well if the injectors faulty there would be missing all the time not just on initial revs.
    But the missing on initial revs on Petrol only and not on CNG is also a clear sign of the faulty or mis functioning of the calm shaft sensor
  17. #17
    capsat's Avatar
    Apr 2006
    Susupe
    8
    9,523
    13
    16
    637 Post(s)
    10 Thread(s)
    @Umar - usually the Socket for the ECU is inside the car under the dash or towards the firewall behind Glove compartment on the passanger side.
    - www.crackwheels.com - A skilled Dictator is much more beneficial to Country......than a Democracy of Ignorant people
  18. #18
    umartahir's Avatar
    Jun 2011
    Faisalabad
    33
    9
    Thanks capsat, i found it.
    Now i ll do the experiments with it.
  19. #19
    chinyoti's Avatar
    Sep 2005
    25
    11,297
    78 Post(s)
    4 Thread(s)
  20. #20
    deltaigor's Avatar
    Nov 2010
    18
    Guys now i got the same problem. The CEL keeps getting on and off and car is stuttering wildly. I know the source of the problem, which is an idiot guy washed under the hood while i was getting my car washed and i was a bit too late stopping him. So does that mean the wiring and sensor is to be changed?
    @fullyloaded2... Can you mention the location of the mechanic you were referring to in ur earlier posts.
Similar Threads
  1. vti check engine light on?
    By getlovingme in forum Engine / Transmission / Powertrain
    Last Post: 07-04-2012, 07:41 PM
  2. CHECK ENGINE LIGHT
    By khalidkhalil99 in forum Engine / Transmission / Powertrain
    Last Post: 25-01-2012, 12:47 PM
  3. CHECK ENGINE light in Baleno, URGENT HELP NEEDED PLEASE!!!
    By PakWheeler in forum Engine / Transmission / Powertrain
    Last Post: 23-07-2010, 10:43 AM
  4. "CHECK ENGINE" Light - Baleno
    By Noushad in forum Engine / Transmission / Powertrain
    Last Post: 14-03-2010, 08:03 PM
  5. check engine light
    By alikanju in forum Engine / Transmission / Powertrain
    Last Post: 18-01-2010, 10:52 PM
